Old 08-02-2011, 10:52 AM
Doopmaster Doopmaster is offline
Default Chain idler question
Is it absolutely necessary to install the chain idler? I have my whole motor installed with chain but I forgot to put the chain idler on and the chain has 1/2-3/4 inch deflection. Thanks
Old 08-02-2011, 11:57 AM
buhz buhz is offline
Default Re: Chain idler question
a new chain will get longer so yes you need it old chain not so much.only other option is shims on motor mount. ride safe BOB
Old 08-03-2011, 11:47 AM
Pilotgeek's Avatar
Pilotgeek Pilotgeek is offline
I don't use a chain tensioner/idler. Though I do have the alignment almost perfect between engine and wheel sprockets.
I only recommend using no tensioner/idler though if you have horizontal dropouts and a dérailleur to tension the pedal side.
