Old 07-30-2011, 09:05 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: jb weld?
Al is right exhaust gases will fill the tank instead of air, no air no fire.
Your results may not be the same,Greg
Old 07-30-2011, 09:25 PM
PerryP180 PerryP180 is offline
To mount the tank permanently, simply use Urethane Windshield Adhesive. It comes in a tube like caulk, you use a caulk gun to put it on. When it dries it's permanent. I've done two bikes this way and never had a problem. I don't even use the brackets. Make sure the two areas to be bonded are clean. I do leave the studs on to help hold cables but they can be cut off.
