Old 09-01-2008, 09:30 AM
NicoG NicoG is offline
Default Engine trouble
Hey I was seeing if anyone can help me out. my 80cc engine kit runs, but its not very fast, dies at idle, and sounds like its grinding. any suggestions???
Old 09-02-2008, 02:13 AM
Hicksy Hicksy is offline
Default Re: Engine trouble
Could be the clutch engaging, check that it's adjusted proberly.
Old 09-02-2008, 04:19 AM
BlueCollarBike BlueCollarBike is offline
When you pull in the clutch handle all the way does it still Die?
If so try screwing in the Idol screw Until it revs UP a little then back out until your happy.
Cheers
Bob
Old 09-02-2008, 06:37 AM
Bikeguy Joe's Avatar
Grinding? Check the clutch cover, inside for ''grinding" marks.
Not very fast is a symptom of a new engine, break it in for a few hundred and it will slowly get faster.
Old 09-02-2008, 06:45 AM
Also ..It may be a new tight drive chain issue as well..It will give you a grinding Sound Or feel..This will get better as the cheap china Chain stretches...And Believe me its Going to stretch.
cheers
Bob
