another 'it wont start anymore' thread
geoldr
Hello guys, so with my bike its just non stop trouble.
I made my own exhaust gasket, was trying it out, it was running real nice, did 2 test laps around the block, halfway through the second it the motor just died and woulnd start up.
It has compression, it has a half full tank of gas, its got spark.
One time when I was riding I noticed my carb was leaking fuel, so theres this screw that i screwed in all the way so it would stop leaking. Could that be causing the trouble? How can I be sure that the engine is getting fuel?
Also I was reading about the magneto key shredding, but I have no idea how to check that.
Please help guys
EDIT:
I think the engine isnt getting fuel. I put in a brand new spark plug, and when I took it out it was bone dry still brand new. Why isnt the fuel flowing into the engine?
Lol, not that literally. I wouldn't know what to look for that's out of place or broken.
What parts would I be looking at that would cause a running engine to stop getting fuel
If you have not installed an in-line fuel filter, it may well be the cause of your problem. A little peace of what ever can get in and stop fuel flow.
A can of carb cleaner is a great investment! Is really easy to clean em out and is a good idea to do once in a while. Great rainy day thing.
cleaning a carberator - Google Search
I have two fuel filters, one inside the gas tank, and one on the fuel line. Im not sure if its on correctly though
Even if on backwards, (like a coffee filter and not correctly like a Christmas tree, top up to the tank) Should keep it free flowing. Is not a given but is less likely to be the problem.
Why do you think it is fuel starved?
A backwards fuel filter is not a big deal. Just ends up filling up with junk and needs replacing sooner. Unless so clogged it is causing the problem.
How many miles do you have on her?
Mines on like a christmas tree. I barely have like 50 miles on it. It's brand new. I took the carburetor apart, and idk it looked normal to me? Put it back on and its still not getting any fuel into the motor =/
I found the problem. When I take out the throttle thing with the needle and c clip, the clip is gone and needle is stuck inside
Could the c clip have gone inside the motor?! Because I cant find it!
I took out the needle, also took off the head and examined the top of the piston and surrounding walls. All looks ok.
Still can't find the c-clip. Could it have gone under my piston? Is my engine totaled?
Attached is a pic of the piston, i think its normal for it to be dirty right? And the needle that I took out with a missing c-clip
But the fact that the clip is gone and most likely went into the engine is OK? Its not gonna break if it fires up?
I'm sorry I don't understand what you mean. I'm not sure where the clip went, it was on correctly, but today it broke off somehow, and its now gone. Considering the only place it really could have gone was inside the intake of the motor, I'm pretty sure its in there somewhere. Also, the threads on the needle are somewhat messed up. What should I do? Just get a new clip, or try to get a new needle somewhere?
hrmmmm.....well, i can tell you from personal experience that the C clip isnt all that much of a piece of metal. if it did slip into your motor, and you've run around and tried to turn it on you would probably have scratched the crap out of the cylinder wall...so if you dont see any gouges count yourself lucky at the moment....now as far as that being the problem, what fuel to oil mixture did you use in that gas? because that was pretty brown looking goo around the inside and on the piston head.....by the way, easiest way to find out if that c-clip got into the motor housing is to take the jug off, shake upside down a couple of times and see if anything falls out......just take the piston off the crank arm first. so as you dont damage it while shaking....also you said you put a different spark plug in? is it a higher quality spark plug or the alternate one that came in the kit?
if its either of those then you should really invest in a NGKB6HS spark plug. they work a lot better than the kit spark plugs. (just be sure to unscrew the little top part of the plug)......also i wouldnt listen to a whole lot of my advice as im not a mechanic and should not be held liable for any directions followed which could lead to catastrophic failure of your $200.00 powerhouse chinese motor......seriously though, find that c-clip....45 minutes worth of taking the jug off and having a look around is a lot easier than throwing a piston ring and scrapping a whole project....believe me i know....ive scarred my piston and the cylinder sleeve with aluminum shavings half the size of a grain of sand....for some decent tear down instructions i would look a little further into the troubleshooting part of the website.....and take lots and lots of pictures before the teardown, during each step of the teardown and while putting the motor back together as this will help you for when you need to tear the thing down again (and you will) .......some needlenose pliers would definitely come in handy if you want to get that piston off that crank arm....and also WATCH OUT FOR THE PISTON RINGS when putting the jug back on. be sure to squeeze them together properly ....i didnt do that and i think that was the ruination of my other motor.....*that was the first time i took the motor apart*.....i didnt take pictures.... anyways let us know the progress and if you find that c-clip.....(check the intake manifold, the fuel bowl of the carb, the ground around where you took the carb apart, the little slide thing for inside the carb, and especially the intake manifold before you tear the motor apart looking for the little bugger) it may save some time and you might be like Oh.....there it is....it must have fallen when i took the needle out....i really wish i hadnt torn apart my motor looking for it.........lol anyways, let us know
I looked up all the guides on how to take the motor apart, and before doing it, I took out the throttle thing the black thing in the carb, and it was stuck in there.
Thankfully, I don't have to take it all apart.
BTW, its so brown because it still getting broken in, 24:1 ratio, and the spark plug is the NGK BP6HS. I bought like 6 of them at auto zone they were cheap
** Oops I did not get to the page two and posted after you figured it out **
One thing I thought of that if it was not found in the carb some where as you were able to find the clip, if it had gone through the engine and it didn't show scratches anywhere, you could look inside the muffler, or shake it out from the input side of a removed muffler.
This would be far easier than taking the engine apart. But most likely if it had gone throught the engine, as small as it is, it would probably have scored the cylinder and piston and maybe more.
prior to see the 2nd page **info only**
If the screw that you tightened in all the way was the bowl drain screw, it is at the bottom of the bowl, that's OK then.
Please note though, I hope it was not the air fuel mixture screw. If that was the case if your carb you have has one, this screw when tightened in all the way will stop the jet from spraying fuel to the engine intake.
I’ve not actually had the chance to see any fuel leak from an airfuel mixture screw if the o-ring was bad (maybe missing), but I suppose maybe it could happen.
If you have fuel at the hose going into the carb then next you would want to know that the needle valve and seat are OK and have the right size o-ring in place. The jet behind the needle valve and so others sometimes located in a cylinder sticking down the middle of the bowl are not clogged is necessary.
On the Briggs engine it is 3.5 turns open counter-clockwise to set the airfuel mixture screw on the engine I have. Then I adjust it one way or the other depending on temperature changes if necessary and to have it running right.
You did say it ran for a while a first. The bowl did fill then. When you tightened the screw, not leak, but eventually the engine stopped. Thinking that the float allowed the float valve to open and fill the bowl with fuel, but then maybe you did shut off the air fuel mixture screw is what happened.
But in the case you did not do that and even know about what an airfuel mixture screw is, then when opening the carb did you see any fuel in the bowl? Otherwise with it dry, I would check to see if at the fuel inlet to the carb, if I can blow a breath of air and have it come though the float valve into the area where the bowl is with the float in the down position (open).
Leaking fuel once happened to a carb that I have which has a pressure overflow, but that was on an engine with a fuel pump. The float was stuck open, so this was to protect the carb from damage.
Measure Twice
Thank you for the information MEASURE_TWICE, and the screw was the bowl drain screw.
I got it running today, I think all was OK. However when I came to a stop and turned off the motor, the muffler was crackling inside. I know this happens on radiators in cars, but is it normal for these two strokes? I never had this before
alright, im glad you found the c-clip and didnt have to take apart the motor. now when you ride the thing and try to start it up, it seems like its not starting? hmmm....by the look of the stuff in the motor you seem to be getting fuel but you think its running too dry and choking off? you got some good plugs from what i understand....i guess lemme ask this then, you got it to start a few times right? i mean it ran around the block once or twice and then it died off from what i understand and now it wont start back up? i would say check the wires going to the motor from the cdi. i can remember one time when i first put my skyhawk engine on the bike i forgot to tape the wires down to my bicycle frame, they ended up touching to my exhaust, melting the plastic sheething and grounding out to each other.......lol that was a fun day......anyways, if thats not it then id reassemble the bike, wait.......you said you made your own intake manifold gasket?.....the problem may be as simple as an air leak between the jug and the manifold.........im just not sure at the moment....too many variables.....as far as the threads on the needle go, they arent really threads, they're grooves that the c-clip snaps into and the closer toward the pointy end you go the more gas you get. you may want to try moving the c-clip down to one notch up from the bottom and try running it there ...anyways keep us updated :):-||
