Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 08-31-2008, 06:56 PM
flyinace flyinace is offline
Default My Erector-Set Bike
I have NO welding skills so when i set out to build a bike i decided i needed to do it entirely with angle-iron and scrap steel and bolt it all together... My creation is the following "Erector-Set" bike---
I posted a picture of my first design in a previous thread (I was looking for left handed nuts). Anyway, I have redesigned the mounts, increased the size of the nuts and bolts to 5/8" and now I think I am satisfied with my first motor bike. It runs off a Ryobi 31 CC weed eater. It can hold be at 24 MPH but it has NO horse power. Fortunately I don't need horse power since i live in FLAT FLAT FLAT Phoenix, AZ.
I created a clutch device out of a small C-clamp i had lying around so the engine can be pulled off the wheel when i don't need it or I run out of gas...The springs hold the engine against the wheel and it is nearly impossible to pull the engine away from the wheel by hand, hence I need the mechanical advantage of the C-clamp... It also allows me to easily control the tension of the friction drive against the tire.
I've ridden it to work several times, which is 6 miles each way... So far nothing has fallen off and it seems to be doing pretty good...
ID:	2276   Click image for larger version
ID:	2277   Click image for larger version
Old 08-31-2008, 07:34 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Re: My Erector-Set Bike
Looks a lot like one of my bikes except it looks more secure. Good job.
Old 08-31-2008, 07:38 PM
comfortableshoes comfortableshoes is offline
That looks very secure. How do you start it? I assume bump start? It must be a stiff start when pedaling?
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
Old 08-31-2008, 07:43 PM
deacon's Avatar
If he can lift it then it wouldnt be too bad and if he can lift it he can rope start it as well.
Old 08-31-2008, 07:44 PM
Peddle starting is no problem at all, especially with the mountain bike in an easy gear.
Old 08-31-2008, 07:46 PM
Its true, in theory, i can rope start it...But I have to turn the c-clamp to lower the engine...That would be pretty difficult while riding. :-)
Old 08-31-2008, 07:53 PM
Motormaker Motormaker is offline
Very nice. It amazes me how so much can be done with so little.
Old 08-31-2008, 08:17 PM
deacon's Avatar
I was thinking lift it pedal and then drop it lol Like one of our friction clutches. Or lift it and then ease the engine down as you pedal. It works pretty darn well and allows me to idle at stop signs.
Old 08-31-2008, 08:25 PM
Deacon, do you by chance have or know where these is a good picture of the clutch you are speaking about? I tried to design something like what you are talking about but everything kept turning out too clunky...
Old 08-31-2008, 08:41 PM
deacon's Avatar
There is one on here other than mine that i like. It is made with the end rod from a chain link fence. If you know what that is. They are just levers that raise the engine. I use a brake lever and cable to pull it
down.
Shoes just uses cables for his....
