SlickmisterN
So about 4 years ago I got into motorized biking with a Honda Advantedge 49cc rear scrubber kit from Dimension Edge. Put it on a Specialized full suspension downhill and now I want a completely different setup.
I really enjoy the torque of the 4 stroke, but the friction drive slip is limiting my grins. The output shaft is super long and not keyed for a clutch. I wanted a vintage board tracker when I first started all this but thought it was out of reach. Now my financials have slightly changed and believe I can produce a tracker that will satisfy my dream.
I have bought a Worksman, and plan on modifying it for the EZM kit. Is there a good thread for specific info on this particular kit, full motor specs and requirements for fit? etc. I have searched and discovered a stretch or drop loop bottom tube modification will be required for clearance.
Are there similar 4 stroke kits that will easily drop into the frame of a Worksman. I'd like to avoid big modifications and using a 2-stroke if possible.
