Old 07-04-2011, 12:31 AM
Ruby478's Avatar
Ruby478 Ruby478 is offline
Default Re: 2-stroke electric starter??
no cause a pull starts not cool enough lol
Oak Cliff Motorized Bike Club is now a private club for Tx members only , majority vote from lead members
Old 07-13-2011, 07:31 PM
Stormsorter Stormsorter is offline
I may be a little late and long winded but here's what I might do with my Stiletto. It's basically the same thing as the kick start someone in the thread mentioned. The basic idea is to find someway to attach a freewheel or one way bearing to your jackshaft and a way to crank it with the back wheel of the ground.
Find out the size of the keyed shaft on the shift kit and get one an inch longer. Then goto Station Inc and get a freewheel, the free wheel adapter that matches the outer diameter of your shaft and a shaft collar if you don't already have one. Looks like SBP uses 5/8 so you can get your longer shaft at Station Inc to. Now the tricky part. Find a 540 (I think? its the size they use in power wheels and most drills) sized electric motor and find some way to drive the freewheel bike sprocket with it.
Even with just a 6v SLA or 7.2v RC battery pack these little motors should be able to turn over an HT, as long as you remember to lift the back wheel off the ground. And they are cheap less than $5 if you don't have to pay shipping. Here is and example of one such motor at about $12 shipped. Or you could just yank one out of an old cordless drill or Power Wheels.
Shouldn't be to hard to attach a chain sprocket to one of these motors. My plan is drill a hole in half inch long piece of rod and another hole for a set screw. Then weld that centered to a metal plate big enough to weld to the smallest single speed bike sprocket I can find handy or cheap. I'm sure there are other ways but that's just what came to mind.
Now if someone could just tell us how if even possible what ferball said about using the same motor to start as an alternator once the engine kicks in, I might actually use this setup. Otherwise the Stiletto gives me plenty of room for the cheaper simpler pull start option.
Or with the right gearing weld an old bottom bracket with the sprocket and one crank arm somewhere and run a chain from it to a freewheel on the end of a jackshaft. It's a lil out there but I would like to see someone doit lol.
Another random thought. I bet someone could turn one of the pull start kits into a kick or electric somehow. Might have to look into that if I buy one for the Stiletto.
Old 07-14-2011, 09:26 PM
NorthMi NorthMi is offline
Check out this Sears power bit stater, I have one for my weed wacker that wants to be a PITA each spring, $10 item this saves my arm and get it running with ease, use my 18v Dewalt drill motor to spin it. Should be easy to adapt a bolt head with the correct size hex to turn the engine over.
Sears: Online department store featuring appliances, tools, fitness equipment and more
Old 10-07-2013, 08:21 AM
turnofftheradio's Avatar
turnofftheradio turnofftheradio is offline
what about a gear mounted over the magneto (like a pullstart but toothed on outside), grind a little out of the case so the gear sticks out of the mag cover at the top or bottom or side, combined with a snowblower/lawnmower starter with the gear and bendix. Probably as wide as a pullstart kit...
I like the idea of that craftsman dealy-o though. simple, but requires a drill, and getting off the bike.
Old 03-14-2015, 11:50 PM
cowboy1948's Avatar
cowboy1948 cowboy1948 is offline
Talking Re: 2-stroke electric starter??
Just buy a pull start.
