Re: motorized kit
your oil mixture sounds right for 20/1 mix which is break in. I think the kill switch disconnect might be the first thing to try along with looking at the spark on the plug as has been suggested.
Also if you have not sealed the intake manifold I would do that regardless. Most of them leak air badly enough to keep it from starting.
those two are the easy fixes after that you need someone with better knowledge than me,
ps welcome
