Old 08-25-2008, 09:47 PM
Hemphire Hemphire is offline
Default clutch arm placement
Hey guys, I busted my clutch arm off of my 2 stroke 5 minutes after taking it out of the box I have the replacement my problem is when I slipped the clutch arm off I didn't pay attention as to what direction it went on. Any one have a pic as to exactly how it is supposed to look when I'm looking on the inside?
Old 08-25-2008, 10:34 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: clutch arm placement
on the bottom of the clutch arm shaft it has a machined flat shape that flat goes towards the short clutch rod inside the front sprocket.
that shaft when out of the cover looks like a half moon on the bottom and the flat will be looking out at you when the shaft is in the cover. did that make since to you?
norms-iron-works.tripod.com
Old 08-26-2008, 07:36 AM
I'm sure it will when I look at it when I get home from work. Thanks for the reply Budy
Old 08-26-2008, 12:02 PM
Ok I got it now. Thanks Norman.
