Old 05-28-2011, 11:01 PM
TANGO's Avatar
TANGO TANGO is offline
Default Heavy Duty back Rim ?
Does any one make a Bolt on Back Rim exclusive to a Motorized Bike that is set up already with a Sprocket that can be switched out and can take many miles of use . If not best options for one to build . Looks Like it will be a Mountain Bike Build .
Old 05-29-2011, 12:09 AM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
Default Re: Heavy Duty back Rim ?
First, a heads-up: what you're looking for has a price tag. But I've bought something like what you're asking about and it's very good. The price is right. Take a look at Pirate Cycles Worksman Wheels. He makes hub adaptors to fit those. The Worksman wheel will take some punishment. The hub adaptor will bolt to its hub, can be adjusted linearly, and the drive sprocket is bolted to the adaptor - so you can change to another bigger one or smaller one easily if you desire. I think Sportscar Pat makes an adaptor too, his should be pretty good also.
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
Old 05-29-2011, 01:18 AM
DuctTapedGoat's Avatar
DuctTapedGoat DuctTapedGoat is offline
I've found my best results from using a disc brake wheel and replacing the disc brake rotor with the drive sprocket. Kings Sales and Service (see top left of the page for sponsor link) sells a top hat adapter that allows you to take advantage of the disc brakes and the bolt on to the rotor mount for your driven sprocket.
Old 05-29-2011, 01:43 AM
Goat Herder's Avatar
Gutter Rider
While I did not agree with the way I got this wheel. Was prelaced to a rim. I relaced it right away and it has been holding up to the Morini 9.4 hp motor really well. I like the concept of this. It is the same width as a basic 9 speed cassette disk brake hub would be mounting to a bike wise. I really like the disk brake on the right hand side. I want another one of these hubs but can't get it right now.
Other than this hub mounting the sprocket to the disk brake mount has been among my favorite set ups with the disk brake style hubs I have.
