| Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. |
08-24-2008, 07:44 AM
CDI to Coil?
Is it possible to convert from a CDI unit to a coil? If so, Can you tell me the best coil to get? Thank You.
Thank You from
Artistic Mind, simple man.
odds10to1
08-30-2008, 08:47 AM
Re: CDI to Coil?
Why not use what you have.
is there a problem with your current set up?
If it works Don't fix it.( unless your looking to improve for Performance)
If your CDI has failed Why not just use another.
cheers
Bob
08-30-2008, 01:24 PM
Re: CDI to Coil?
Thank You BlueCollarBike,
Just trying to simplify things. Seems to me a coil would be better than a CDI, plus cheaper also. But I really don't know, I'm not a mechanic. Also, I'm not sure if I have a problem with my CDI. My bike would crank, then stop running. Crank again, then stop running. Then wouldn't crank at all. I'm running into all sorts of problems trying to swithch from Japanese to American. $7.00 for a $1.19 spark plug is rediculas, plus a $6.00 s/h charge on top of that.
Thank You from
odds10to1
08-30-2008, 01:57 PM
Re: CDI to Coil?
WHO is the one ripping people off !!
$7 for aspark plug...Your kidding right.
Your Symptoms may be a lose wire ( cdi) or a sticking kill switch..try unhooking the kill switch and see if it still cuts out.
Let me Know Or give me a ring.
bob
BlueCollarBike
860-673-6457
08-30-2008, 09:59 PM
Re: CDI to Coil?
The only place I knew of until I stumbled upon 'MotorBicycling.com' was where I bought the motor. They get $7.00 per plug plus $2.00 s/h. They get $21.00 per CDI, plus $5.00 s/h. If you buy both at the same time, you pay both s/h charges also. Their CDI's will only use a plug that has no cap. I was never able to find one that had no cap that was 14mm thread and 11mm reach. Thanks to 'Motorbicycling.com' My problems are being solved at a fraction of what it would have costed me. Thank You again.
Thank You from
odds10to1
08-30-2008, 10:07 PM
Re: CDI to Coil?
well for future reference You should look at ngk-b6hs or champion L7J for a spark plug.
And you are able to unscrew the wire from your CDI and rundown to a Auto parts store for a replacement wire.
You can cut the wire you purchase and screw it into the CDI.
hope this helps.
cheers
Bob
08-30-2008, 10:17 PM
Re: CDI to Coil?
My local Checker auto parts store has the NGK, Champion, and Autolite for around $3.00.
08-30-2008, 11:16 PM
Re: CDI to Coil?
On my CDI that came with the engine kit the spark plug wire runs directly into the CDI box and there appears to be no way to remove it or open the CDI. How do you guys replace the original spark plug wire with this kind of setup?
08-31-2008, 12:35 AM
Re: CDI to Coil?
You just twist it out, check this thread........ http://motorbicycling.com/f3/spark-p...motor-765.html
08-31-2008, 09:05 AM
Re: CDI to Coil?
I already have taken care of that. I am now waiting on a fuel filter. No parts or hardware store had any in stock. I had to order one. Be here Tuesday 9-02-2008.
Thank You from
odds10to1
| Thread Tools |
| Display Modes |
Linear Mode
