Old 08-23-2008, 04:48 PM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
HS Math Teacher
Default NGK Spark Plug
What is the REAL difference between the B5HS, B6HS, and B7HS spark plug? I have the 6 and the 7. Don't know which is better and why it's better
Old 08-23-2008, 06:34 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: NGK Spark Plug
They have a different heat range
NGK.com
Old 08-23-2008, 06:41 PM
pedalpower's Avatar
pedalpower pedalpower is offline
iirc the 5 is hotter than the 6
El Metodo: La Improvisacion
El Objectivo: Explorar un continente que solo conocen por los libros
El Equipo: La Poderosa
El Che
Let the Solution BE the Revolution
Old 08-23-2008, 09:30 PM
MrLarkins's Avatar
HS Math Teacher
6 is hotter than 7?
Old 08-23-2008, 09:50 PM
Dave31's Avatar
For NGK spark plugs there is a simple rule of thumb:
Low heat rating number (for inst. BP4ES) "Hot spark plug".
high heat intake due to long insulator tip.
High heat rating number (for inst. BP8ES) "Cold spark plug".
Low heat intake, due to short insulator tip.
Old 08-23-2008, 10:58 PM
MrLarkins's Avatar
HS Math Teacher
which is better for out happy times? i have the stock plug, a NGK B6HS, and a NGK B7HS
which should i run?
Old 08-23-2008, 11:57 PM
Pablo's Avatar
Pablo Pablo is offline
NGK B6HS but the 7 will work fine as well.
Old 08-24-2008, 12:28 AM
misteright1_99's Avatar
I run the B6HS and am very happy with it...
Old 08-24-2008, 12:29 AM
Saddletramp1200's Avatar
Saddletramp1200 Saddletramp1200 is offline
Custom MB Buiilder
Well done Guys! As a "loose" rule every step up in heat range adds 10 degrees to combustion temp @ time of fire in m/s-2 Or thats the theory.
Only Bikers know why dogs love to stick their heads out of car windows,
Old 08-24-2008, 08:25 AM
Bikeguy Joe's Avatar
Would that be 10 degrees C or F?
