Old 08-22-2008, 10:45 PM
luke duke luke duke is offline
Default Slower when hot
I decided im about run in (have about 300km on the clock) I went on a 60 km ride today and found that i lost top end after about 10 km. It is there temporarily but it doesnt hold it in fact some times misses a beat. I figure that i may be running a little rich and the plug may be oiling up at full throttle. Plug looks o.k slightly dark. I currently have a .75mm jet in on a 70cc with baffle shortened on exhaust and a few extra holes in air filter. Should i look at leaning up maybe throwing in a 70mm jet?
Old 08-22-2008, 11:29 PM
Default Re: Slower when hot
It has no problems at full throttle when climbing (lower revs) only on the flat when i get around 53km/hr. When cold it will run upto 58km/hr without missing a beat.
Old 08-23-2008, 05:46 AM
Bikeguy Joe's Avatar
What color is your plug?
Old 08-23-2008, 10:02 AM
Jemma Hawtrey's Avatar
Jemma Hawtrey Jemma Hawtrey is offline
It sounds a little odd that you are having power problems but you have a dark plug.. have you checked the choke is coming off completely?
It might also be worth looking at the ignition system - it might be as that gets hot its less efficient - also are there any parts of the wiring running close to the hot exhaust.. that might be causing the problem or be a part of it..
Jemma xx
"....Look, no pedals... *thud*..." The mating call of the motorized-biker.
"RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork.
Old 08-23-2008, 12:15 PM
misteright1_99's Avatar
Check you head bolts (when cold). Look for leaks (oil) around the base of the cylinder and head.
Old 08-23-2008, 03:46 PM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
HS Math Teacher
this is exactly as mine is doing...from a cold start, it runs fast (up to 32mph)...then within 5 minutes i can't get past 20 mph...and i got a black spark plug and oil around my exhaust port
Old 08-23-2008, 03:48 PM
O.K i rechecked the plug and it was a nice tan colour no carbon deposits, I might make it a little richer as a precaution. Now to get my facts straight on using the needle adjustment (the moving up and down can be confusing when you dont know which end is which) To get richer I move towards the tappered needle point to get leaner I move up on the end with the the groves (washer end no needle point!) Is this correct. Also tighten the head slightly.
Old 08-23-2008, 06:42 PM
You are correct on the needle adjustment, clip towards the tapered end id richer, towards the flat end leaner. I would not tighten the head bolts unless they need to be. If you have a torque wrench I would torque them to spec in a cross pattern. Do you see any oils stains around the base or head?
http://motorbicycling.com/f3/cylinde...pecs-2934.html
Old 08-23-2008, 06:47 PM
Sounds like a bad head gasket or loose head bolts to me....Might want to check them with a torque wrench also, in a cross pattern.........
Old 08-23-2008, 08:34 PM
MrLarkins's Avatar
HS Math Teacher
well, i've already replaced ALL gaskets once AND torqued the head bolts and 2 of those snapped off...and yet, I was following NORMAN's suggestion in the other thred...my luck with this engine sucks! but I'm sticking with it and trying everything i can think of...my next try is to rejet
