Tired of Using a Torch to Bend Cranks.
rohmell
1,531
6
New York
Yes, I am tired of using a torch to bend the pedal cranks out for clearance for pull-start and centrifugal clutches, so my plan is to use a rewound microwave oven transformer controlled by a variac to heat the crank to bending temperature.
To give you an idea of what I am talking about:
YouTube - High Current Microwave Oven Transformer Test
Of course, the variac will be uses to control the output so that there will be some element of repeatability and safety when using such a technique.
Anyone ever try such an approach?
bairdco
a guy who makes cool bikes
Aug 18, 2009
6,537
264
i use a 6' long pipe and a crack in the cement under my shed. no heat involved.
wedge the crank under the shed, put the pipe over the other arm, and it bends easy peasy japaneasy.
i could probably bend the crank into a straight line with enough pressure.
"Give me a lever long enough and a fulcrum on which to place it, and I shall move the world."
Archimedes
corgi1
2,272
KCMO
Oh please Mr.,don't hurt my screw drivers,They're old and don't work like new,but we all get that way in time and they're all I got,lol
42blue15
136
St Louis metro, USA
(youtube video)....
It's interesting to look at, but why do you think it will work better than a torch?
With a torch, you can only heat the spot that you want to bend...
rohmell
1,531
6
New York
Depending upon the placement of the two leads from the transformer it will allow localization of the high current heat, similar to using a torch.
But, before I give this a whirl, I am going to try using a 12 ton press for my next crank bend, and see how that works out.
