Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Cruiser Bicycles
Motorized Cruiser Bicycles The beach cruiser has always been great bicycles to motorize. They just look good with a motor. Use this section to share and discuss about motorizing this classic.
Old 05-05-2011, 12:04 AM
surfingbird surfingbird is offline
Default Noob help - first build - so many questions
Ok s lets start by saying this is my first build
I have a schwinn phantom re issue
It's fully broken down and ready for powder coat
I have few questions that I have stumbled on after lurking for a few weeks
1. What type of crank and pedals do need , apparently there is some clearance issues?
2. Grubee , raw, etc what's everyones favorite kit
3. Brakes?
4. Tires? 26"
I want to learn from everyones mistakes because as a frequent forum visitor I understand the vast amount of knowledge you guys have
So please help me make the right decisions first
And please address any issues I might have left out
Thx in advance
Old 05-05-2011, 04:32 AM
DuctTapedGoat's Avatar
DuctTapedGoat DuctTapedGoat is offline
Default Re: Noob help - first build - so many questions
1: Depends on frame size - you might need an extended crank on the left side to clear motor and exhaust. Won't know until you mock it up though. If you go with a pull start kit, you'll need to extend your right cranks considerably.
2: My fav kit is Raw (@ Products )- but that's just personal opinon. They're all relatively the same thing, dodge the red filter housing carbs (CNSv2) though. Biggest thing is find a reputable retailer that will stand behind their product with good customer service and a rocking warranty. If you see "Limited Warranty", run like ****, cause if you put gas in it it's void.
3: You can run any kind of brakes, but I suggest a dual pull brake lever so you can get 60-70% rear and and 30-40% front. Side pull caliper is bottom of the barrel, v-brakes are next best, disc is awesome (see #4 for exception), and hub brakes are best. AVOID coaster, they will die so quick and it's dangerous.
4: For wheels and tires you have a few options. For tires, go either heavy duty thorn resistant tubes with liners; slime; and thick knobby tires, you can get a set of armadillo kevlar compound tires with hd thorn resist tubes with liners and slime, myself personally I use solid tires from AmeriTyre - but it takes an inperson custom fit at a local retailer to ensure they work well. For wheels there's options too - there's HD axle kits with hub brakes (threaded lefthanded freewheeling sprockets and a pullstart), ragjoint sprocket mounted on at least 12G or greater spokes, and disc brake rotor mount sprocket (exception in #3). As far as wheel size - 26" is standard. As with driven sprockets vs drive sprockets and their gear ratios, when you go 29"/700cm wheels you have a tough bottom end, but a great top end (and if you build ragjoint style sprocket mount it's more at risk of damaging rims). The smaller wheels (21"-24") will get you more immediate acceleration, but lower top speed at the same peak RPM.
Old 05-05-2011, 06:50 PM
sketchman sketchman is offline
Good warranty or cheap enough that you don't care.
The eBay kits are cheap and a never ending supply of parts will always be there. If you like experimenting, the cheaper the better I say. I'm new too. I'm glad I didn't go more expensive to start with. I had no hesitation about tearing into the engine and seeing what makes it tick. I probably wouldn't have with one of the praised Morinis, for instance, that cost more than my entire build. But that's me.
