Old 08-19-2008, 06:42 AM
ricland ricland is offline
Default GEBE vs DAX
GEBE vs DAX
Anyone have experience with both they can share?
ricland
Old 09-03-2008, 10:22 PM
flynchef's Avatar
flynchef flynchef is offline
Default Re: GEBE vs DAX
i have been running a Dax 70cc for over 4 years had a livefast take a dump after 6 mo. dax is the best as far as im concerned. plus Dax offers the best customer service of all i have contacted.
Old 09-04-2008, 12:01 AM
Large Filipino Large Filipino is offline
I have heard good things about the GEBE and I have a bit over 3,000 miles on my Titan it's so reliable watch my videos man.
I think it all boils down to preference.
Do you want a belt drive or do you want a chain drive?
I've never had a GEBE so I can't comment on it.
Old 09-09-2008, 11:54 AM
Me-N-Mike Me-N-Mike is offline
I have had a good experience with my GEBE (about 600 miles so far). So far all problems I have experienced have had more to do with my bike than with the kit. My only complaint with the system is the lack of a true freewheel. If you intend to do a fair amount of pedaling w/o the motor, the GEBE may not be the best kit. If you are planning on running with the motor most of the time then I have no problem recommending the GEBE (though I have no experience with other systems).
We like our bike.
It is made for three.
Our Mike
sits up in back,
you see.
We like our Mike
and this is why:
Mike does all the work
when the hills get high.
Old 09-09-2008, 04:43 PM
paul's Avatar
paul paul is offline
Administrator
i put over a thousand miles on my dax titan before it was stolen. the only maintenance was i changed the oil and had to adjust the idle one time. it was a phenomenal motor and i have another one ordered. also dax takes care of his customers and you will not find a better dealer out their in my opinion
Old 09-09-2008, 05:57 PM
3,000 miles on my Titan. I looked into a freewheel sprocket cause less drag is always a good thing but I've been pedaling without engine rather easily. Aside from the little bit of noise from the spinning clutch drum when your pedaling it's really not that bad of a drag at all. In fact just the way it sits I can pedal without engine just by shutting it down.
The gearbox I can put in my pocket. It's a 5 to 1 ratio so that clutch drum does spin quite a bit when your rolling down a big hill but you really don't feel it or at least I don't and it's not gonna fall apart on you.
Yep. That Titan is SOLID. I can't talk for the GEBE cause I've never owned one so again I believe it's preference.
Stay tuned for my trike in a few weeks.... yes. Titan.
Front wheel drive. 20 inch front wheel.
Old 09-22-2008, 03:58 PM
jg767 jg767 is offline
I was going to match up a dax titan with a staton rear hub with a lefthand freewheel sprocket, but my titan order went awry and I bought acomplete staton chain drive kit. I love the freewheel option, I think it's worth the expense to put it on the titan, you just need to mount the proper size sprocket to the freewheel.
Old 09-22-2008, 04:44 PM
Jemma Hawtrey's Avatar
Jemma Hawtrey Jemma Hawtrey is offline
GEBE to be honest would get my vote - the belt drive system is quiet, reliable and like all machines works very well if set up right.
I have done over 900 miles of running on one belt. I can make an easy cruise of 30mph and a top speed of 35mph. This is on the standard gear - it would be faster on the #14 gear.
Mine is a 32cc two stroke motor with a tuned pipe (tanaka manufacturer for carts - better mid range). I got up the steepest local hill here today (1:5 grade) and from a rolling start at 15mph I was still accelerating at the top at 26mph.
I get no transmission noise and good speed and reliability.
While it is true that GEBE is one of the more expensive machines its definately worth the money in my opinion.
Jemma xx
"....Look, no pedals... *thud*..." The mating call of the motorized-biker.
"RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork.
