V twin - 50cc bike...
fishguts
313
southeastern MA
I'll be building one as soon as engine #2 arrives. I'm pairing up two 25cc weedeaters, connecting them with plates at about a 60 degree V with a common drive. The intakes will be connected and it will run off a single 50cc carb. I'll post photos so if anyone wants to copy the procedure they can follow along. There are a couple challenges but I don't think they're insurmountable.
fishguts
313
southeastern MA
Here's a "before" picture with the two motors mocked up together. They are essentially identical but were used in different configurations so the engine cases are not exactly the same. It would have been easier if they were, but I'll work with that I have. The next step will be to make patterns for the connecting plates.
You can see I have them set up so their flywheels are on opposite sides. This puts the intake ports in the middle and will allow for a common manifold and single carb. This also means that their rotations are opposite, the right hand (forward) motor in the picture being the one with rotation the same as the driveline needs to be. So ... the left hand (rear) motor will need a two-gear setup that will turn a shaft in the proper direction below the cases and connect on the drive side. This means the connecting plates will have a place for mounting bearings and the shaft.
wheelbender6
4,059
221
TX
I had been looking for a way to add a second, non-operable cylinder for looks.
You are going to build the real thing.
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
N.M.
Very cool fish ! I come across motors like these every once in a while for free simply because folks just don't know what they have . A simple quick carb overhaul with a new diaphragm and their back.
I am looking forward to how you overcome these hurdles! Thanks for sharing!
