Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 02-10-2008, 12:50 AM
Markpee Markpee is offline
Default How do i mod this type of pipe baffle?.
It has 2 round metal parts on both ends one going into the engine and one coming out. and in the middle it has a thin tube thats dented in the middle and is full of holes.
Soo i gess like this -0==0
Old 02-10-2008, 07:07 AM
RedB66's Avatar
RedB66 RedB66 is offline
Default Re: How do i mod this type of pipe baffle?.
There are a couple different ways to modify your pipe. You can drill more holes in the small part of the tube or you can cut off one end of the baffle. Keep in mind that these changes will increase the loudness of the motor. If you dont mind.....Please introduce yourself....not required, just like to know who you are and where your from.....Thank You, Redb66.
MOTORBICYCLING.COM STICKERS
Old 02-10-2008, 11:13 AM
Bikeguy Joe's Avatar
MP- Like he said- drill more/bigger holes or I'd cut the middle out altogether.
Welcome to the forums.
Old 02-11-2008, 09:18 AM
paul's Avatar
paul paul is offline
Administrator
i have the same pipe and drilled some holes in it. didn't do anything but make the pipe a little louder. i have talked to others that have drilled out the other style pipe also and most said no real noticable difference except the noise
Old 05-28-2008, 01:23 PM
jezusjonz's Avatar
jezusjonz jezusjonz is offline
I made a baffle ejector the other day that I can kick it in and out about an 1 or so...and drilled a few extra holes in the top cap and found no noticeable difference other than I can control when its loud and when its not and ......it looks kinda cool....
Terry
Old 05-28-2008, 03:17 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Santa Cruz Scooter Works
I found that using a 3M green srrubbing pad works great in lowering your db levels. Plus its works better than fiberglass.
