Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 08-15-2008, 11:01 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default need guess, educated guess or swag
okay I got a gas tank off a bolens engine (same as ryobi), my chainsaw bike get about five miles from that tank of gas. I am trying to figure out what size the tank is cause it seems like terrible gasoline milage. Some of it may be leaking out around the return hose, but I doubt that much is.
Old 08-15-2008, 11:06 AM
jasonh's Avatar
jasonh jasonh is offline
Default Re: need guess, educated guess or swag
Pop the tank off and close up the holes. Then start adding a cup of water at a time and see how much it holds.
Old 08-15-2008, 11:11 AM
deacon's Avatar
its on the bike and full of gas. I was hoping someone would know so I would have to do that.
Old 08-15-2008, 12:04 PM
Ilikeabikea's Avatar
Measure the inside dimensions and get the cubic inches and divide by 144................
Old 08-15-2008, 12:07 PM
jasonh's Avatar
If it's full of gas, pop the gas line off and drain it into a container and measure how much gas is there. Then just pour it back in
Old 08-15-2008, 12:31 PM
Ranger Ranger is offline
I have a ryobi 31cc gas tank that I pulgged all the holes in. after reading this thread I just went outside and made a quick measurement of how much gas it holds.
The tank holds 1 1/4 cups of fuel if just pouring it in. You can get an extra 1/2 ounce if you shake alll the air out of the tank.
There you go.
However, I would suggest making or buying a bigger tank.
deacon's Avatar
Well I learned two things when I went out to the bike.
One it was empty when I filled it and I filled it from my mixing bottle. Estimated amount of gasoline is 12 oz which seems pretty close.
Two there is a leak in the tank. I have five new plastic canteens coming so I'm just going to ride the mtb25 till they arrive. I just rode the mtb25 and it seems to rev higher and has a better friction wheels so it does just as well as the chainsaw33.
I emailed the man who is donating a Weed Whacker for the brochure build and I pick it up tomorrow. I should be working on the build for a couple of days. Then I guess I will be looking for a new hobby again. It's like the antique cameras, once I knew how to do it, I lost interest. In this case I at least get to ride them to the store for my effort.
At this particular moment the little mtb25 is my favorite. After the brochure is done, I might have a motorized bike yard sale.
