Old 08-14-2008, 07:55 AM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
HS Math Teacher
Default Is It Normal...
to have an oily air filter? Well, mine is oily. I can't tell if its backflow from the carb or splash coming up from my chain!
Old 08-14-2008, 08:09 AM
Bikeguy Joe's Avatar
Default Re: Is It Normal...
If you are running very rich, your filter can get very oily. If your filter gets oily, it will make your engine run very rich.
Old 08-14-2008, 05:51 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
wash it out with soap and water put back on without oiling it even if its damp with water it will run you'll dry it out quicker if you ride it around a little bit. as you run these engines fuel will pulse out of the carb and collect in the filter eventually oiling up the filter.
norms-iron-works.tripod.com
Old 08-14-2008, 05:55 PM
jasonh's Avatar
jasonh jasonh is offline
I just spray mine with carb cleaner and wring it out.
Man, carb cleaner does everything. I use it for so many different things.
Old 08-14-2008, 09:58 PM
Including cause tumors of the liver and kidneys, use nitrile gloves at the least when you use it.
Old 08-15-2008, 10:48 AM
jasonh's Avatar
Oh, lovely.
