Old 08-14-2008, 06:41 AM
smithmule smithmule is offline
Default will it work?
im guessing a nu vinci hub has a 1 way bearing in it .. what if u flipped that aroung and then flipped the whole wheel around and used the sprocket to drive the bike? super gearing or am i totaly wrong?
Old 08-14-2008, 09:05 AM
jasonh's Avatar
jasonh jasonh is offline
Default Re: will it work?
If it has a one-way bearing and you flipped it around, then it would only work in reverse I think...
The proper way to use it would be to use a jackshaft like the sickbikeparts shifter kit to drive the nuvinci from the right side.
I would love to have a nuvinci connected to the motor. Too bad they're so darn expensive. For the cost of the nuvinci and shift kit, I can buy a used but working motorcycle
