Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 08-13-2008, 11:10 PM
tylerlough tylerlough is offline
Default vibration with drill vs. no drill front mount; 70cc
I didn't mind drilling the frame on my crappy Huffy but I would like to avoid drilling the frame on my new Moon dog. But if no drill mounting means more vibration then I will drill a hole in the frame. So what method makes less vibration?
Thanks
Old 08-23-2008, 07:52 PM
Andyinchville1's Avatar
Andyinchville1 Andyinchville1 is offline
Manufacturer/Dealer
Default Re: vibration with drill vs. no drill front mount; 70cc
HI,
I have never drilled a frame BUT it seems to me that if an engine is directly bolted to the frame snugly it will transmit vibrations either way.....Only way to reduce vibrations is to add a vibration dampener of some sort between the engine and frame.
Hope the is helps you.
Andrew
Old 08-23-2008, 09:56 PM
Dave31's Avatar
Dave31 Dave31 is offline
I agree with Andrew...I don't think it makes a difference if you drill it or not. If it's going to vibrate, its going to vibrate no matter how it is mounted.
Old 08-24-2008, 10:38 PM
I'm going the no drill then, bought a 1.5 inch muffler clamp, some bolts to replace the studs, and 1in. by 3in. 1/8 steel plate. All this was about $4.50.
Still waiting for my friend to bore out my new sprocket.
Old 08-18-2009, 10:23 PM
Revo Revo is offline
I drilled mine, put a piece of tire tread between mount and bike, very little vib, and it looks good.
Old 08-27-2009, 10:29 AM
Deadend's Avatar
Deadend Deadend is offline
i was going to suggest this - even on a non drilled mounting.
Not tire tread but a bit of inner tubbing. I've used this to dampen vibe on many many motorized applications ranging from a utility case mounting on an enduro to a fake mini gun on a motorcycle's handle bar (lol)
just be sure to torque it down and semi-perm locktite it
Old 08-27-2009, 04:00 PM
spad4me's Avatar
spad4me spad4me is offline
Your huffy was probably made of steel.
What is the moon dog frame made of ?
Use a sanding drum in a drill to enlarge the hole for your sprocket.
Motorized bicyclist
Old 08-27-2009, 04:10 PM
freewheeling frank freewheeling frank is offline
i drilled my cranbrook and it lasted about 10 miles the hole wore to about twice the diameter and the single bolt through the frame broke now am running a sbp adapter with inner tube and no problems
Old 08-27-2009, 04:16 PM
city of angels city of angels is offline
you could also try the front motoremount from sbp and maybe this will solve the no drill part
Old 11-21-2009, 06:05 AM
carpetrugger carpetrugger is offline
Unhappy Re: vibration with drill vs. no drill front mount; 70cc
I drilled my frame like it said in my instructions for over sized down tube's. This was before I found the motorized forms. Now I know this is not a good idea as it can weeken the frame right where the motor mounts. My front case mount developed a nasty crack in it on the left side where the stud screws into the block. This has to be the weekest part of the case and it's right where it needs to be it's strongest. I fixed it by making a solid mount and replacing two of the case's screw's with grade #5 studs and bolting my new bracket to it on the left side. This is on a Schwinn Jag with a steel frame. New mount will also work as a torque strap. I had all the welding done for 20 dollors at a local sheet metal shop. Even if you don't use this method for your fix at least get the holes welded shut, it could save your life! Here are some Pic's this is a work in progress but I used this new bracket with it mounted through the frame and it worked fine (the crack in the case did't get any bigger after two tanks of gas) I can't fiqure how to post pic's and its late tonight I will try again tommrow. I can't fiqure out how to down size my files to post pic's or why it's asking me to. I've posted lots of pic's on other site's with no problem. Can some one explane how to do this.
