Old 08-13-2008, 12:40 PM
brucemg51 brucemg51 is offline
Default sprocket wobble
I've just installed the rear sprocket, along with the two binders and backing plate. I can't seem to get the sprocket to stop wobbling. All nine of the bolts are as tight as I can make them. I tried loosening the bolts a little on one side, but that didn't help. Any suggestions
Old 08-13-2008, 03:22 PM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is online now
Default Re: sprocket wobble
don't make the bolts too tight, let them be a little loose. then just try to true it by adjusting the bolts as needed to reduce the wobble. that's what helped me.
Old 08-13-2008, 03:37 PM
But then, aren't the bolts going to loosen up when you start riding?
Old 08-13-2008, 06:56 PM
stude13 stude13 is offline
use nylock nuts
Old 08-13-2008, 07:59 PM
pedalpower's Avatar
pedalpower pedalpower is offline
don't know if it stops the wobble but I don't have any. I think it's because I installed 2 sets of backing plates. the first is the set that has 2 pieces and the second is the set of 3 pieces that staggers the seams like brickwork. I noticed before that the plates will bend a little when you tighten them down. worked for me. jon
El Metodo: La Improvisacion
El Objectivo: Explorar un continente que solo conocen por los libros
El Equipo: La Poderosa
El Che
Let the Solution BE the Revolution
Old 08-13-2008, 08:43 PM
Originally Posted by stude13 View Post
use nylock nuts
What about threadlock or locktite or something like that?
Old 08-13-2008, 10:21 PM
nylock nuts lock themselves with nylon
Old 08-13-2008, 10:49 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Torque the bolts slowly in a "star" pattern... Don't worry about getting the bolts as tight as you can!!! Worry more about slowly tightening the bolts, & getting the sprocket to spin straight! Don't over torque!
Old 08-14-2008, 07:10 AM
I've definitely overtorqued. I'll back up and do it over.
Old 08-14-2008, 10:57 AM
BlueCollarBike BlueCollarBike is offline
Very good advice.
loosen all the bolts a little
spin the tire/sprocket and slowly bring a piece of chalk ( or Marker) close to the top of the sprocket .
It will leave a mark at the high point.
Tighten the high point more then the low.
Also if your unable to get the sprocket to stop wobbling ...
take a block of wood and wack the high point with a hammer .It may sound barbaric but it works.
hope this helps.
Cheers
Bob
Home
