Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Old 08-09-2008, 07:57 PM
UncleKudzu's Avatar
UncleKudzu UncleKudzu is offline
Question Lever Actuated Coaster Brake?
would it be possible to use a coaster brake as a hand brake? could a coaster brake be used on the front wheel? if so what would be involved?
i'm thinking about repacking the rear hub of my bike while i'm waiting on the engine, and i started wondering if the sprocket were removed if a rear hub might not work for a sturdy front hub. then i thought about that brake in there...
Old 08-09-2008, 07:59 PM
gadgetman80 gadgetman80 is offline
Default Re: Lever Actuated Coaster Brake?
WOW, did that ever get some gears turnin in my head!!
Old 08-09-2008, 08:01 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
wouldn't you have to leave the sprocket on the wheel and use the lever to pull it backwards and lock it down. Isnt that what happens when you back pedal.
Old 08-09-2008, 08:08 PM
Try to follow my thinking....may be hard for some:
drill a small hole in the sprocket and fasten a screw to hold the chain.........
attach a small length of chain in a fashion that could be hooked to a cable...
spring load the reverse side so as to release the brake...........
I think the rest can be figured out
Old 08-09-2008, 08:09 PM
Sometimes I have a hard time following my own thinking
Old 08-09-2008, 08:21 PM
UncleKudzu's Avatar
i don't really know what happens inside the hub, so i was wondering if a little arm with a return spring or something might replace the cog altogether?
Old 08-09-2008, 08:23 PM
UncleKudzu's Avatar
yeah, me too! but it's probably such a good idea that there's simple a reason why it wouldn't work
Old 08-09-2008, 08:26 PM
Large Filipino Large Filipino is offline
Mount the coaster to the forks. Get a bike chain,wrap it around the sprocket to a free sprocket welded to your handlebar. Alignment is critical so you need to strengthen your gooseneck so your handlebar won't loosen left or right. Weld a (you all seen this before) "safety lever" used in old school ten speeds with the curled handlebars that connect to your brakes so you can activate it from the top of the handlebar. Weld it to the free sprocket so it sits above your handlebar. To activate,push it down.
Man,this may be an answer to all them Schwinn chopper bikes with no provisions for brakes up front.
For the Schwinn chopper bikes maybe just a simple foot control directly off the sprocket.
Old 08-10-2008, 08:15 PM
Radmanfly's Avatar
Radmanfly Radmanfly is offline
I once considered replacing the bendix arm with a brake disc and welding a gear onto the spoke hub so that I could convert the friction hub to a clutch. The original gear would be chain driven backwards from the motor and the disc free to rotate until I wanted the hub to turn. By applying the brake to stop the now rotating bendix arm (brake disc) it will stop and the hub will go.
www.farleysradiator.com
Old 08-10-2008, 08:47 PM
Radmanfly's Avatar
Lightbulb Re: Lever Actuated Coaster Brake?
Inside the hub are two wedges. When the gear rotates backwards, it forces the wedge shaped halves lock into a stationery cone (attached to the brake arm which is clamped to the frame) and forces them apart. They then pry out against the cylinder inside the hub and slow it down. The metal appears to be graphite impregnated so it will not squeal and will absorb some heat, and not be metal on metal. At least thats how I remember the one I took apart 30 years ago. Wish I could remember my gf's birthday!
