Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Cruiser Bicycles
Motorized Cruiser Bicycles The beach cruiser has always been great bicycles to motorize. They just look good with a motor. Use this section to share and discuss about motorizing this classic.
Old 03-03-2011, 10:02 PM
cdoom cdoom is offline
Default almost ready to roll
So I've had this kit for a while but wanted the right bike to put it on. I found the Vito Modems Deluxe on bikebuyers, and ordered one. The motor bolts up perfect, however the carb cover rubbed the frame. I went to my local Ace Hardware and purchased a brass plumbing 180* fitting and clamp to extend it away from the frame. The tank was also a problem due to the thickness of the frame so Lowes assisted with a roll of pipe hanger to solve that issue. I caugt heck trying to remove the clutch over screws, and stripped one out but managed to get them off. Now everythin has been mocked up except getting the chain on the 10 tooth sprocket. I could use some pointers there. I'm gonna try to add some pics now, as I'm writing this on my droid.
Old 03-04-2011, 02:47 PM
fall_down_stand_up's Avatar
fall_down_stand_up fall_down_stand_up is offline
Default Re: almost ready to roll
To get the chain on the sprocket,pull in the clutch and push the pin down to lock it then take a flat head screwdriver and you can turn the sprocket and roll the chain around it....
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
