Old 08-10-2008, 12:07 PM
Lightfoot's Avatar
Lightfoot Lightfoot is offline
Default Re: Have engine-need bike
I guess I'm confused now. I thought your kit came with a wide 3 piece crank. All of the 4 stroke kits I've seen came with the wide crank as part of the kit. I've seen some kits with 1 piece cranks and some with 3 piece. Do you mean your kit just has the crank arms and not the square shaft spindle part? If so here is a link to a conversion kit that includes that part.
Pyramid 3 pc, Bottom Bracket Conversion Kit | BikepartsUSA
Originally Posted by Nitrohorse View Post
The 4 stokes are a wider engine than the 2 strokes, so the wider crank is necessary. They engine kit contains a three piece "crank set" (two crank arms, and chain sprocket) which requires the "square shaft bottom bracket" to mount the crank set on. Most (practically all) of the bikes I looked at have the one piece cranks on them and that renders the three piece crank set that came with the kit useless. I know my terminology is not the best, and I'm probably not explaining myself in the most accurate way as well.
At any rate, I need the square shaft type bike to bolt my crank set onto.
The Ashtabula type one piece crank will not work for my 4 stroke engine.
Old 08-10-2008, 06:02 PM
Nitrohorse Nitrohorse is offline
You hit the nail on the head. My kit does not contain the square bottom bracket shaft.
The kits supplies the two cranks and the sprocket for a square shaft. The cruisers I've seen have the one piece crank/bottom assembly, which I cannot use.
The site you supplied me will certainly help me though.
