Old 08-07-2008, 04:17 PM
Ranger Ranger is offline
Default Ryobi 31cc clutch problems
I have 2 ryobi 31cc engines that I want to take apart and get the best parts from both of them. The problem is that I can get the square shaft clutch drum off. I did everything that deacon said to do, took off the spark plug and filled cylinder with rope. That worked but I just cant get the screw out, I took a slot screwdriver and put some vise grips on it; once I had the screwdriver lined up I twisted with all my might. Nothing
The one on my first engin ecame off just fine, I'm not sure what the problem is?
Old 08-07-2008, 05:13 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Re: Ryobi 31cc clutch problems
Okay bad news time. You can try some thin oil down the shaft let it sit for a day and try again. (first choice)
2nd choice cut the bell off enough to get a bigger screwdriver in it. If you have one off you can tell about were to saw it to get to the screw head better.
I would be a little concerned about trying to heat it, but I guess you could try if you have paramedics on standbye.
Thats what I would do somebody else will have a different answer I'm sure. I also like the old sledge hammer approach on the vise grip on the screw driver handle. Not to mention my all time favorite for auto bolts that were struck.... the old hydrollic jack trick.
I also have a screwdriver end for my ratchet wrench. Lots of torgue that way when you add a three foot length of pipe.
Old 08-07-2008, 06:07 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
That screw is it a left hand thread? One option is a hand impact driver that will loosen the stuck screw. On one of my posts I show the hand impact driver being used on the screw on the engine's gear drive.
A little heat might be needed if that screw was put on with a thread locking compound.
norms-iron-works.tripod.com
Old 08-07-2008, 07:57 PM
Well the deed is done, I drilled out the screw with a 1/8" drill bit. No more problems now, as long as i dont want it to be a weed eater again.
Old 08-08-2008, 09:24 AM
deacon's Avatar
LOL good work. I love it when someone sees the end game. Who gives a rats behind as long as you accomplish the end you want.
Old 08-08-2008, 12:38 PM
jonboy2five jonboy2five is offline
impact wrench/drivers usually work really well, and you wont strip anything. they are both cheap and easy to find...
