Re: The project begins
my guess and it is just that is that it fired for him. If it fired but couldn't get enough revs up the clutch wouldn't spin.
Here is what I would do.
1.Empty out his gas probably been in too long.
2.Put an ounce or two of new gasoline/oil mix in
3.give it a generous spray or two of carb cleaner into the gas tank.
4.Take the plug wire loose and pull that through the carb several times.
5.That should clean the gunk out of the carb.
6.Pour any gas left in the tank out
7.put in a couple of ounces of new gas into the tank
8.put the spark plug wire back on
9.try to start it (follow the starting directions ie choke settings).
If it doesn't start but tries you can repeat the steps, then if it still won't start go from there.
My experience is that the carb is most often gunked from leaving gas in it over the winter. Replacing the spark plug usually isn't necessary but it would be my number two move. I think most of the lawn mower shops rebuild the carb when it isn't really necessary.
My guess is that it will start up for you.
