Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Wheels, Brakes and Suspension
Wheels, Brakes and Suspension Keep your motorized bicycle on the road with suspensions, rims, tires and disk, drum and caliper brakes
Old 08-06-2008, 12:26 PM
~macaddict~'s Avatar
~macaddict~ ~macaddict~ is offline
Default Disc Brakes...
Hello, I am thinking of putting my new engine into this bike>
Giant Bicycles - Tran Send LX (2008)
But I dont know if I could since it has disc brake F & B. Do you think it will work?
I say thanks in advance :]
Old 08-06-2008, 12:30 PM
jasonh's Avatar
jasonh jasonh is offline
Default Re: Disc Brakes...
You have a couple options.
1. You could get the sickbikeparts shifter kit and keep your rear disc brake.
2. King's Sales & Service can make you a left-side sprocket that bolts to your disc brake mount. No sandwiching the spokes, but you lose your disc brake in the back.
Old 08-06-2008, 12:33 PM
Ok, hmm i'm new to this stuff so....
Could I get a link to both of them?
Old 08-06-2008, 12:47 PM
ocscully ocscully is offline
Both are sponsers of this site look to the bar on the left of this page both are located there
ocscully
Old 08-06-2008, 12:59 PM
Ok, thanks. One last question. But if I remove the back brake can't I just install the stock sproket on there with no issues, or do I have to go with one of those two options?
Old 08-06-2008, 01:33 PM
jasonh's Avatar
you should be able to install the stock sprocket on there no problems I think.
If you don't go with a shifter kit, I would highly recommend putting some type of brake on the back. Front only is baaaad.
Old 08-06-2008, 01:46 PM
ok, so if i remove the disk brake on the back and leave the one in the front BUT put a V brake on the back that'll work. No need for the left sided sprocket or the shifter kit.
Old 08-06-2008, 01:54 PM
jasonh's Avatar
Well the stock sprocket is a left-side sprocket
it's just King's will give you a sprocket that mounts to the disc brake mount instead of attaching via sandwiching the spokes.
And yeah, I think a V brake would be just dandy on the rear. Never had disc brakes, but the V brakes are my fav out of the rest.
Old 08-06-2008, 02:00 PM
Ok, cause I wanted to use one with disc brakes cause I have heard that using v brakes with a motor with run the brakes down really fast. If they don't really run down like they day they do, might as well just use a bike with F & R v brakes.
Old 08-06-2008, 02:10 PM
jasonh's Avatar
The brakes being worn down quickly is due to stopping from higher speeds. I don't think it's anything about V brakes in particular.
Disc brakes will be safer because you will have more stopping power. Something you're going to want when doing 25-30mph.
