Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop
Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop Custom fabrication and projects, tanks, frames and more.
Old 02-25-2012, 02:39 PM
DaveC's Avatar
DaveC DaveC is offline
Default Re: Welcome To The Welding & Metalworking Forum
Made in the USA or in China like about everything else?
Old 02-26-2012, 02:57 AM
MEASURE TWICE MEASURE TWICE is offline
http://www.itw.com/itw/search_Result...rchString=weld
I searched and Dang if your not right. But note the automated weld stuff say CA, that USA... whippe! I shall see if I can land a job there.
MT
Old 03-31-2012, 02:20 PM
Mike B's Avatar
Mike B Mike B is offline
Bought a welder, a Lincoln Century 80. Just a little flux core 115 VAC, 80A unit good for up to 1/8".
Works good, this is my first weld.
The only thing in my garage with 4 wheels is the lawnmower
Old 03-31-2012, 11:28 PM
Nice. I have to see about doing some lighter weld with a MIG for both flux and inert sheld gas weld.
I have a 130 that runs on 115 volts.
I want to fold and bend some steel to a shape for covers over delacate carb linkages and also moving pulleys and belts for safety. I think it would be OK if I can get it right so I don't burn through all and never attach what I make lap joints for in the folds.
MT
Old 04-02-2012, 08:31 PM
thegnu's Avatar
thegnu thegnu is offline
lap joints are a good trick , heres another 1 you can try if butt welding to light gauge metal an I can get behind it I will clamp a peice of 1/4 inch thick copper plate behind the weld you can weld all day on that copper an it will never stick or burn through.
four wheels move the body . two wheels move the soul
Old 04-03-2012, 02:06 AM
So you get enough heat to the work and welds OK, but its sort of the same as laying the metal on a thick metal table as the table is ground an weld the two pieces of metal.
Moderates the heat some I guess.
MT
Old 04-03-2012, 09:21 AM
thegnu's Avatar
MT if its a steel tabe you can weld your peice to it steel dont stick to copper . but yes the copper will wick away any excess heat .
Old 04-03-2012, 12:16 PM
2door's Avatar
2door 2door is offline
If I need to fill small holes I've used a penny clamped to the metal behind the hole then rosetta weld. When you're done the penny will come off and leave a welded shut hole in its place. Good when doing auto body stuff and filling screw holes where chrome or parts were attached to the body.
Magnets are also useful for holding small, hard to clamp parts in place until you get them tacked together.
Old 04-03-2012, 04:13 PM
I got a few magnets meant for welding, those triangle laminate with steel of various sizes.
When I got the minimal training to use time at a shop welding we had a thick metal table, but stuff stuck to it as it was steel. They used a wire brush occasionally to clean off weld splash beads.
It was said that with the magnets holding the pieces to weld on the table and the table had the ground clamp connected that enough current flows for what otherwise small pieces the clamp connection would be impractical.
You’ve explained about the copper and that it does not stick but is a very good heat sink, thanks.
MT
Old 05-06-2012, 04:32 AM
OG-Whizzerdude's Avatar
OG-Whizzerdude OG-Whizzerdude is offline
What would be a good guage metal to make a seat pan from. It will have no springs and will be pretty close to the rear fender.
MotorBicycling.com
