Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop
Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop Custom fabrication and projects, tanks, frames and more.
Old 01-24-2011, 01:58 PM
azbill's Avatar
azbill azbill is offline
Default Re: Welcome To The Welding & Metalworking Forum
some cool stuff to read !!!
thanks for sharing the 'OCD' with us
Bill
Intelligence is learning from your own mistakes,
Wisdom is learning from the mistakes of others
www.ezmotorbike.com
azgrampa@gmail.com
Old 01-24-2011, 02:02 PM
Goat Herder's Avatar
Gutter Rider
Something I dug up a long time ago... http://motorbicycling.com/f36/huge-l...ers-24414.html
Old 01-25-2011, 04:09 PM
Dan's Avatar
Dan Dan is offline
Staff
Cool Goat, ty. I reformatted this PC and had lost that link. I had saved it first time you posted it but forgot to save.
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 01-29-2011, 12:33 PM
Hammond Egger Hammond Egger is offline
The $64,000.00 question. With a flux wire welder on 16 or 18 guage metal do you push or pull the puddle.
Old 01-30-2011, 12:45 AM
shiloh0 shiloh0 is offline
only thing in oxy-ac they showed me in welding was to use for cutting, then on to stick/mig. i remember my dad brazing a cracked radiator neck back in the day. held
forever. thanks for the vintage manuals
"You must cultivate the feeling that a warrior needs nothing"-don juan
Old 01-30-2011, 05:05 AM
Dan's Avatar
Dan Dan is offline
Staff
I have the same question Hammond. Came to the conclusion after watching vid after vid on the net that I would just try both until I found which method worked best for me. Seems like so many folks use one or the other method that I could not find a definitive answer. More seem to push but is close.
Push & Pull Technique for Welding: Welding Basics: Techniques for Tig, Mig & Arc Welds | eHow.com
But I have maybe 5 hrs total welding time so dunno.
Old 01-30-2011, 03:19 PM
flybytaco's Avatar
flybytaco flybytaco is offline
Metal Molding Madman
i have never flux wire welded before but since pushing a puddle has more penetration i'd say push. I push with my mig as well as the tig. when you pull it makes a thinner bead btw less penetration tho
the evader
Old 01-30-2011, 08:23 PM
turtle tedd turtle tedd is offline
The weld puddle always moves in front of the tungsten (TIG) or nozzle (MIG) regardless of the thickness of the metal...it is never "pulled"...the penetration of the weld is controlled by the angle and speed of the tig torch/mig gun , the heat setting and the amount of filler material (wire) added to the puddle..when welding Aluminum , the mixing of the shielded gases , Argon and Heliumn in the right proportions also affect the penetration of the weld...when looking for the best quality of steel welds it would be an Argon and Co2 mix..
Old 01-31-2011, 08:16 PM
Gutter Rider
I have been using Argon and Co2 mix.. My welds to me look better with it. I am not the best welder tho not all my welds look pretty lol..
Old 02-01-2011, 02:45 PM
Lowandslow Lowandslow is offline
Just remember "with slag you drag". Flux core would be pull and solid wire w/gas would be push. Dont forget to change the polarity of your machine when switching from one to the other.
MotorBicycling.com
