Old 01-24-2011, 01:49 PM
Goat Herder's Avatar
Gutter Rider
Default Re: Starting from stops?
Originally Posted by mybike View Post
My chopper has 48cc starfire 2 cycle chrome with a centrifugal clutch. I start off with dead stop NO problem . 50th rear sprocket.
C clutches are a little different than the manual clutches. I gotta recon they will take way more abuse. Yet still wear and tear wise why not just a bit of peddle of the line with it? That is still better on the motor..
Old 01-24-2011, 10:17 PM
bitsnpieces bitsnpieces is offline
Definitely; I'm getting better at pedal starting and it sounds like it works wonders.
Without it or proper pedal start, I can hear the gears kick in and just sounds mean.
Imagine trying to pull something and you suddenly just tug and pull compared to getting a good grip and slowly pulling harder and harder, both works, but there's a difference in how your arms will feel at the end of it.
Old 01-25-2011, 01:49 AM
Black_Moons Black_Moons is offline
I use the clutch to take off all the time.. its probley not good for clutch life however.. I do it via the following method:
Rev the engine to medium/high revs, SLOWLY release the clutch untill rpms start to drop, Then you open the throttle wide open as you slowly release the clutch a little more over a few seconds.
Takes a little pratice not to overrev or stall out.
