electronic ignition module
militarymonark
I was wondering if anyone had a scan or good link to the directions of hooking up an electronic ignition module instead of having points.
Here you go.
Jim
can you give me an explanation about this, I know we talked on the phone about it but I'll have it annotated so I can look back to make sure I didn't forget anything thanks
Reverse the leads on the module. One way is positive ground, and the other is negative ground. It depends which way the magnets are turned in the flywheel as to which way works best.
Have fun,
so the wire going to the stop switch, is that the wire that was going to the condenser? And do I make a stop switch in place of the condenser? Does anyone have a picture of what it looks like already installed
No need to post picture, as it just can't get any simpler!
There are TWO connectors on the module, just reverse them to see which provides the most spark.
Module mounts with a single screw, one wire goes to magneto, and the other to ground.
Have fun,
