Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 02-04-2008, 12:01 AM
MotorbikeMike's Avatar
MotorbikeMike MotorbikeMike is offline
Dealer
Default Incremental Chain Tensioning, Chain Management
HI well, I thought sure that I had written this here, but in case not, here goes.
Other than a true spring-loaded guide, which some I knew in the past had made, the best tension roller LIFTING the chain is NONE.
This is how it came to be that I invented the aluminum T-Shirt.
Remember that when you move the engine forward the chain slack reduction is twice the distance of the movement of the engine. One full link-set is one inch, therefore the MAX that you would ever need to move your engine would be 1/2 inch. Additionally, good is good enuf, and there is no need for perfect, which, actually does not exist.
Now, take your rear sliding motor mount, make a pattern on a piece of extruded aluminum strap, not to exceed the width of the mount or it can hang up in the chain.
Originally I drilled the holes, and slid them on the studs in-between the rear motor mount and the engine case. AFTER pulling the engine in and out several times it occurred to me that when I aligned the front-end on my 55 Chevy, that the shims had a tab-handle, and did not require removing the bolts, just loosen, pry open, slip in and re tighten.
This is where we are now, your shims look like t-shirts, and the "arms" of the t-shirt lay on top of the 2 studs, with the body of the shirt hanging down, full-length to space the engine evenly, and rock-solid.
Next installment, after you-all ask anything you like about this, I'll explain the other section of Chain Management, which we invented (Kevin "evil elvis" Waddle, and Meself), the Upstop Roller.
Mike
www.ezmotorbike.com www.simpsonmotorbikes.com
Home of the EZM Q-Matic Products
08 Racer and NEW Model 10 production bikes
Whizzer, Starfire, and SkyHawk
Old 02-11-2008, 10:01 AM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Incremental Chain Tensioning, Chain Management
Good stuff. I really don't have, or at least don't think I have, room to "move the engine". But 1/2"? Maybe! Please post pictures (I'm a visual guy).
I am indeed interested in the next installment.
My chain is really the weakest link on my bike. When will the silly thing stop stretching?? (I'm serious - anyone know?) I take two links out, then two more, then two more and this is all after it was pretty tight to start with. This is driving me crazy!!
I took a long ride on Saturday and sure enough the chain stretched so much it wouldn't stay on. Maybe two more links!!
Old 02-11-2008, 06:58 PM
Bikeguy Joe's Avatar
300 miles....that's what I got to before the chain was done stretching.
Look for bending/fractures of the frame if the chain just won't tighten.
Old 02-11-2008, 10:35 PM
Pablo's Avatar
OK I have a long way to go. Frame and motor, etc are all very solid. Thanks.
Old 02-12-2008, 05:28 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Thats a lot of stretch.
Old 02-12-2008, 10:51 PM
Dealer
Hi, well, ok step two in the conquering of the "chain slappin' blues". After I once started building these bikes, I began to use KMC HD cruiser bike chain instead of whatever was in the kits.
Sadly, on about my 8th or 10th engine SpitFire had changed to the bigger, dumber, heavier chains. I revolted, and returned to the Bicycle Chain. These can be overcome with KMC's BMX chain, tho the pitch is a wee bit different.
Here a dremel, with a diamond bit is your best friend, work out all the burrs, sharp edges, reshape the teeth as needed, AND you should run the chain thru, over and over, refineing your teeth's shape, till the chain does not try to "climb" the sprocket, once this is done we can proceed to improve the rest of the system.
Also know, that the "shoulder" of the sprocket sometimes needs some relieving, AND that your master link too many times does not have the DOGBONE shape, and you either need to relieve that shoulder, or "dogbone" that master link. Taking care of this will stop many unexplained chain derailing, snapping, or blowing the master link episodes, and maybe long walks home?
I NEVER use the kit chain, they must be made of some metal version of silly putty.
Sooo, replace your chain, adjust it with the T-shirts, (With your carb as LEVEL as possible).
AFTER you replace your chains, we will get on with step 3 of the "Chain Slappin Blues".
Are ya with me?
Mike
Old 02-13-2008, 04:01 PM
bravofire84's Avatar
bravofire84 bravofire84 is offline
ok this is my first time building a bike kit and my chain is to long i think i might go with a "aluminum t-shirt" show pic if u can.
Old 02-13-2008, 04:19 PM
paul's Avatar
paul paul is online now
Administrator
did you try to remove any links from the chain first?
Old 02-13-2008, 05:00 PM
Deacon- You'll have three links by tomorrow after noon....that's just a prediction on my part.
Old 02-13-2008, 05:05 PM
no not yet
