Old 08-03-2008, 09:55 PM
darkthorn_pro darkthorn_pro is offline
Unhappy clutch dose nothing
My clutch dose nothing I mean nothing none of the internal parts move none
It will no disengage for any thing
Old 08-03-2008, 10:07 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: clutch dose nothing
On your last post you said you have alot of play in your clutch arm...is your clutch arm pointed towards the rear tire?
If it is...be sure your pin and ball are in the center of the drive sprocket. I know one guy who got a kit from Revolution cycles and it was missing.
Old 08-03-2008, 10:32 PM
yes and yes the stuff just dosent move at all
Old 08-04-2008, 12:09 AM
cdoug50 cdoug50 is offline
I had same problem when I first received my engine. Luckily, I tried to disengage the clutch before mounting the engine. Could not for the life of me get it to move until I called the seller and he explained that sometimes when these engines set on the shelf for awhile, the clutch will freeze and it's just a mattter of putting enuff pressure on the clutch arm to get to move. I laid the engine on it's side and put just about all my weight on the clutch arm and it worked. Was still stiff for a couple days after that but now works freely.
Old 08-04-2008, 09:23 AM
Bikeguy Joe's Avatar
What moves and what doesn't move? Can you push the arm? If you can, you are saying it doesn't push the rod and ball? You can't see the plate move with the cover off?
Old 08-04-2008, 09:24 AM
You got the cable tight enough? If not, you can pull the lever and all that will happen is the cable, lever and arm will move and nothing else.
Old 08-04-2008, 09:36 AM
Pablo's Avatar
Pablo Pablo is offline
Disconnect the cable. Can you move the clutch arm on the engine at all? (don't pound it, just push it with your fingers or a short 2x4)
Old 08-04-2008, 09:09 PM
Angry Re: clutch dose nothing
nothing moves inside the clutch the internal parts will not move no matter how hard you push the arm
Old 08-04-2008, 09:44 PM
misteright1_99's Avatar
Have you tried loosening the star nut on the clutch plate?
Old 08-04-2008, 09:49 PM
Yes but as i said nothing moves it has nothing to do with that side of the motor the rod wont push in no amount of adjustmen on the other side of the moto witll help that belive me ive tried
