Old 01-03-2011, 11:46 PM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
Default Re: Dent in gas tank?
Originally Posted by 2door View Post
This might work but if you try it, please, please make sure there are NO gasoline fumes in the tank before heating it.
But where's the fun in that. Why, I think it might provide a little extra light to see what you're doing (never mind that your eyebrows are singed off).
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
Old 01-04-2011, 12:44 AM
adam valentine's Avatar
adam valentine adam valentine is offline
Originally Posted by Black_Moons View Post
Anyone know how to get a large dent outta a gas tank? The 1.8L black one..
Fell over today and hit a post on the way down...
I do paint less dent repair and there are cheaper tools of what i use sold at auto zone for 5 bucks including tax its a flat rounded edge piece of metal and all you do is use slight pressure and work the dent from the outer edge to the inside it will get smaller with minimal pressure use very bright lighting tho so you can see it and don't work too fast unless the paint has cracked, you will not notice that it ever had a dent when you are done, if it has a crease forget it
Old 01-04-2011, 07:50 PM
thimmaker thimmaker is offline
You can also just fill the dent. Sand off the paint in the dent and spray on a coat of self-etching primer (walmart). Let it dry good and start filling with thin layers of Bondo spot putty (walmart). Dry well between coats with a hair-dryer and over fill and let dry completely. Wet sand it to the right contour, prime and paint. Iv'e done 2 old Whizzers and a Cushman Eagle like this and can't tell the difference. And i'm sure the Gasoline doesn't really care if there's a bump inside.
Old 01-05-2011, 09:41 AM
kipharley's Avatar
kipharley kipharley is offline
Venice was selling some in the Swap and Shop Thread! Seems to me they were pretty cheap? Kip.
Old 01-05-2011, 04:50 PM
2door's Avatar
2door 2door is offline
I dented a tank a while back, stupid, I dropped it, and needed a way to un-dent it. I made this little swing arm hammer thing that I can insert into the fuel tank and hammer away by manipulating the wire from the outside. It works great on small dents that aren't creased too bad. The weighted thing on the end was just something I found in a junk drawer. It fit on the 5/32 stainless welding rode and even had a set screw to keep it there. I made this one just to have the desired reach for the dent I was working on but one could be made to reach the full length of the tank and adjustable for shorter reaches.
