Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 11-28-2010, 04:44 PM
atombikes atombikes is offline
Default HF 79cc Utility Bike
A long time ago I bought one of the Harbor Freight 79cc 4 stroke engines one sale, got a great deal. Due to work around the house, the engine has sat in the box for months. Now, my time is freeing up, and I am planning my build. After long thought, I think I know what I am going to build.
Here is my plan. I am going to build a custom "longtail" utility bike, similar to this one:
by using pretty much the same technique shown on this person's website:
Long-Tail Cargo Bike
Also, I am going to modify the seatstays and the area directly behind the seatpost to add an engine mount for my 2.5hp Harbor Freight engine. The goal would be to make enough space to leave the HF engine as it comes out of the box (leave gas tank/air filter/etc on). I think to keep things simple, the engine will drive the rear wheel on the left side, and the bicycle crankset will drive the rear wheel on the derailleur side. So the drive will be like a minibike on the left side, using a centrifugal clutch.
I solicit help from you guys because you have experience. I plan on a 26" wheels. I will use the engine mainly to keep my speed up between 20 and 30mph.
Questions-
  1. What is the best/cheapest source for a 5/8" clutch for this HF 79cc engine? Northern Tool has this one, is it appropriate? Hilliard Extreme-Duty Centrifugal Clutch 5/8in. Bore, 12 Tooth, 35 Chain Size | Brakes, Clutches, + Hubs | Northern Tool + Equipment
  2. What is the easiest clutch to adjust for idle rpm? The Hilliards have different spring kits to adjust the clutch; maybe all these types of clutches are similar?
  3. What is the approx. idle speed for the Harbor Freight 79cc engine?
  4. Will a size 35 chain be appropriate?
  5. Should I plan on using a jackshaft?
Sorry for such a long list of questions,
Thanks, Ed
Old 11-28-2010, 05:53 PM
silverbear's Avatar
silverbear silverbear is offline
The Boy Who Never Grew Up
Default Re: HF 79cc Utility Bike
In spite of having just finished a greyhound build I'm afraid I can't give you much advise for what you want to do. As for the cheapest clutch, I don't know, but I think you're going to need something to change the gearing, as you say, perhaps a jackshaft ... maybe some kind of CVT. Unless you're good at fabricating you'd best follow what someone else has done and even then it may be difficult. I know my own limitations, so I got a ready made transmission to transfer the power from the engine to the rear sprocket. Be forewarned that just because you got a great deal on a motor and it is a nice motor, no doubt about it, that will be one of the cheapest parts of your build. Be prepared to spend more getting the power to the rear wheel than you spent for the engine. Nobody wants to spend more than they have to on a build, but there are some things you just can't get around. Hopefully someone more knowledgeable will jump in here. I would suggest reading up on other greyhound builds so you start to get an idea of what's up and which direction to take. Good luck to you.
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
Old 11-29-2010, 11:47 AM
Thanks for your response, Silverbear. I have been following your latest build, it looks great. Seems (to me) like one reason for these different transmissions that I see discussed on this board would be to change the engine speed to match what is needed at the rear wheel. And that is a balancing act between required torque and speed. And since most people are trying to motor existing bike frames, it is best to combine everything onto on plate and keep things compact, bolts right to the engine and doesn't require custom fabrication. But these solutions typically cost several hundred dollars. I think I can keep my cost down a little by fabricating the jackshaft mount into the frame or engine mount. But if I do that, I will also have to figure out how to tension that chain....
I guess mainly what I need to know right now is, for those that use centrifugal clutches, is there a preference of one over another? Like Max Torq over Hilliard? I can run thru the gear calculators later to determine how large each sprocket must be to get in the desired rpm range.
Thanks
Old 11-29-2010, 12:22 PM
silverbear's Avatar
Glad you like my Greyhound build, thanks. I'd say if you can fabricate something yourself, go for it. I love to see low budget, quality builds. It's a lot simpler if you have deep pockets and pay for the best of everything and then just bolt it together. I shouldn't say "just" as there is a lot of skill necessary anyway. But you know what I mean about having to figure things out as you go. Lots of satisfaction in that. Somebody smarter than me will have to advise you, though. I know my limitations. Elmo and Neattimes (not sure how that's spelled) are both pretty sharp with this stuff. If they don't see this thread I'd PM them asking for help. I can cheer lead though...
SB
Old 11-29-2010, 12:23 PM
silverbear's Avatar
Seems to me that Rusty built a jackshaft into the frame, but I think that was with a 2 stroke. Camlifter is another one good with jackshafts and such.
SB
Old 11-30-2010, 07:10 PM
Felton Felton is offline
That long tail would be awsome. If you could find an 8 tooth centi clutch you might be able to get away without a jackshaft. I don't think you would be happy with it though.
Here is an equation I came up with a while back. It will show you how much reduction you need. All you have to do is plug and chug. You will need to know is your RPMs and your ratio.
A= Motor rpms
B= total ratio from motor to final sprocket
C= rpms at the wheel
D= feet per Min
E= Feet per Hour
F= Mph
A/B=C
Cx6.7=D
Dx60=E
E/5280=F
Top rpms would be about 5500. If you were to use that clutch thats 12t and the biggest driven sprocket is probably 72t so your reduction would be 6/1(no jackshaft). Thats a top speed of about 70 mph. Thats just not realistic.
20/1 would put you around 20 mph 15/1 is 28 mph.
Old 11-30-2010, 11:25 PM
corgi1's Avatar
corgi1 corgi1 is offline
you have gears , hills w/and weight hauling,you want a shift kit,the jack shaft gears can be fenagled to adjust the standard motor to wheel ratio in high gear and the lower ones are for hills etc
Old 11-30-2010, 11:52 PM
He wants his speed between 20-30 mph all I think he needs is a jack shaft.
Something else you might want to look at befor you mount your engine is how much space it is going to take up. If you look at my rack mount hf it is centered up on the axle yet I am practically sitting on the gas tank. You might be better off putting the motor in the frame if at all possible.
Old 12-01-2010, 12:29 AM
thine82's Avatar
thine82 thine82 is offline
i have a idea to make a electric bike with a razor scooter that is only 100 dollars.. can a friction one do the job ? or how about making it with a big sprocket and a centrifical clutch??? that has teeth or a belt.
and how do i get to find posts taht i have made and people respond to???
Old 12-01-2010, 01:22 AM
corgi1's Avatar
we will say the power allows the elec. scoooter wheel to move you along at 15 mph,if the tire is used (in reverse,face the scooter backwards) it will move the bigger bike wheel along at the scooter speed ,you can go to a smaller wheel on said scooter and get more hill climbing power as a friction drive set-up,,, but the gear bolted to the bicycle wheel and tire would have to be the same size as that bicycle wheel and tire for the scooter motor to have the power to move the bike,,or the motor would have to run through 2 - 3 jackshafts to get the ratio the original scooter wheel/tire/and sproket, and motor shaired,by the time it reaches the bike wheel sproket to have the ability to movethe bike,if you notice ,the sproket on the scooter wh. is almost as big as the wheel ,the scoot is just so fast and that will limit the bike to that speed,its all the power/speed it has to give
MotorBicycling.com
