Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 11-15-2010, 01:47 PM
cigron's Avatar
cigron cigron is offline
Default EZM Q Matic
EZM Qmatic transmission
I was told that I should put a few drops of oil on the
Clutch bushing. I would like to know if someone would
Be kind enough to put up a photo .I would not want to
Put it in the wrong place. And mess up perfectly good clutch.
When I learn how to put up photos ill try to be more help
Then I am now. I learned I lot of this site I would like to contribute
To it maybe be of some help to someone.
Old 11-15-2010, 02:08 PM
MotorBicycleRacing's Avatar
MotorBicycleRacing MotorBicycleRacing is offline
Default Re: EZM Q Matic
Put a few drops of 30 weight oil on the 5/8" shaft behind the 10 tooth
sprocket and inside the bearing bracket.
There are a few spacer washers there.
Ride the bike to heat the bushing up so it soaks the oil in.
The MaxTorque clutch has an oilite bushing only on the sprocket side.
See the diagram here
http://www.maxtorque.com/html/ss_clutch.html
Old 11-15-2010, 06:26 PM
azbill's Avatar
azbill azbill is offline
attached is a blow-up picture of the Max-Torque six shoe clutch,,,
part #3 is where you need to oil
you want to run the bike for a bit to get the bushing hot enough to weep the oil into it
(make sure the engine is off so the oil doesn't get all over the clutch shoes/bell,,,ask me how I learned that !!!)
Bill
Intelligence is learning from your own mistakes,
Wisdom is learning from the mistakes of others
www.ezmotorbike.com
azgrampa@gmail.com
Old 11-15-2010, 07:21 PM
jbcruisin's Avatar
jbcruisin jbcruisin is offline
Good info guys.
EZ Motorbike Dealer
http://ezmlebanon.blogspot.com/2009/...f-lebanon.html
Old 11-15-2010, 08:35 PM
cigron's Avatar
Thanks. you guys been A lots of help.
MotorBicycling.com
