Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Tavern > Travels and Adventures
Travels and Adventures Use this forum to tell us about your motorized bicycle travels around the neighborhood or around the world
Old 07-29-2008, 03:20 PM
Sassifrasstea Sassifrasstea is offline
Question Hot Weather Riding
I was just wondering if it was too rough on the motor to ride in 100+ degree temperatures. Have you guys ridden any distance in this kind of heat? I can't seem to find anything on this subject. I live about 12 miles from work and would like to ride, even in this heat, but don't want to hurt the bike. Thanks for any thoughts on this.
Old 07-29-2008, 03:27 PM
jasonh's Avatar
jasonh jasonh is offline
Default Re: Hot Weather Riding
I don't see a real problem with riding in hot weather. As long as you don't leave the bike just idling with no air movement, you should be fine. Quite a few motorcycles use air-cooled engines much larger than these. Hope that helps.
Old 07-29-2008, 05:12 PM
Dave31's Avatar
Dave31 Dave31 is offline
Here in AZ I ride well above 100deg. all summer long. Lose a little power do to the heat but other then that no plroblems. Last July made a 140mile trip to Mexico in the heat, just stopped a lot for a few minutes every now and then but that was more for me then the motor.
Old 07-29-2008, 05:15 PM
datz510's Avatar
datz510 datz510 is offline
I ride my HT in 115F temps with no problems. They run fine at higher temps, just dont run them too hard & take breaks every now and then to let the engine cool down.
Old 07-29-2008, 05:32 PM
jasonh's Avatar
no offense guys but I am SO glad I don't have 115deg heat to ride in anymore
Old 07-29-2008, 06:44 PM
azbill's Avatar
azbill azbill is offline
my rear needs me to stop more than the bike does
12 miles should be fine
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 07-29-2008, 11:16 PM
Pablo's Avatar
Pablo Pablo is offline
I think I rode once when it was 80°F. Bike did fine.
Old 07-29-2008, 11:35 PM
lennyharp's Avatar
lennyharp lennyharp is offline
I commute at 4:30 PM and 6:00 AM in Phoenix area, and could swear that at 110 - 115 the motor has less power that in the morning at 80 - 90 degrees. This could be my imagination as the brain fries at 105 and I am not sure how sane I am after 30 years of commuting like this. I do not find any problems and have 1300 miles with no failures on a Robin Subaru EHO35 running thru a Staton gear box. Pablo we can find even less than 80 degrees if we go to the cooler at 7-Eleven.
LennyHarp of Lenny's Bikes & Things
http://lennyh.com
The true value of a man is not judged by what he has, but rather by what he can do without.
"We are what we repeatedly do. Excellence, then, is not an action, but a habit." -- Aristotle
Old 07-30-2008, 08:53 AM
jasonh's Avatar
Yep, pretty much all motors will make less power once they hit a certain temp. Nothing out of the ordinary though.
Heh, I rode to work this morning and I was almost wishing I brought a light jacket...was a bit nippy Bike ran great though.
Old 07-30-2008, 07:00 PM
Thank you so much for the input. Glad I don't have to worry about it now.
