Old 08-18-2015, 10:53 PM
tgaydos's Avatar
tgaydos tgaydos is offline
after much cursing and many tries my seatpost was finally free, it took a torch, a deadblow, a pipe wrench, some kro-oil, and the help of my dad to break it free. after that he offered to take it to work and see if it'll fit in his sandblaster or at the very least get the hard to sand places aka all the joints.
"The most important thing is to have a good relationship with your bike you have to understand what she wants."
Old 08-20-2015, 06:04 PM
survive1990's Avatar
survive1990 survive1990 is offline
Finally Running!
Old 08-20-2015, 07:43 PM
DRBS's Avatar
DRBS DRBS is offline
you need to put a better exhaust on that or your going to fry those rings you need some back pressure to keep the oil between the lands and the rings also it is needed to make power a good expansion chamber will give you more power than a open exhaust
hang on a second I think ill use my nox now
Old 08-20-2015, 07:48 PM
Tony01's Avatar
Tony01 Tony01 is offline
Yesterday, went over to my neighbor's to switch the flywheel from my old block to the new block. I have neither a 15/16" socket, nor a torque wrench.. so this saved me over $100
Also mounted my other motor on the bike. Unfortunately it does not have a kill switch wire so I could not hook up the digi-tach.
Also figuring out a motor-surging problem. I thought it was in the carb but started with the simple stuff, and found that the petcock/filter/tubing were kind of clogged. Still gonna go and clean up the carb and check the float level again.
I don't always listen to Alice in Chains..... but when I do, SO DO THE NEIGHBORS
MxTrq clutch tuning | msrfan 2spd | 212cc 2spd | 3.5hp 2spd | Thud 2spd | CVT tuning
Old 08-20-2015, 10:15 PM
thxcuz's Avatar
thxcuz thxcuz is offline
i discovered what that popping sound was AND I put on a nanner seat. It's ugly but I like sitting back a bit
I have a need for slightly increased speed
Old 08-29-2015, 09:31 PM
xseler's Avatar
xseler xseler is offline
Replaced both sets of brake pads and checked all fasteners in anticipation of my upcoming Colorado trip. The rear caliper still had the small shoe that came with the caliper ---- installed the long Bontrager pads on both ends (what I had in my 'overstock' box). The bike stops very well! I may take it to my sister's farm tomorrow, she's got 160 acres of cattle trails that are actually fun to ride!
Also, looking forward to a steak and a beer in the Mile High State!!
You're never lost until you run outa gas.
Old 08-29-2015, 11:01 PM
mapbike's Avatar
mapbike mapbike is offline
Hey Hey Mark... How the heck are ya?
Dang-it....! trails, steak, beer, sounds like you have a very good plan there.
Old 08-30-2015, 05:15 PM
xseler's Avatar
Got a new project.......maybe. This fuel tank is off of a Honda XL500 and is bigger than it looks. It's got a slight dent in the 'passenger' side that will require a bit of love. I believe that I can make it work. I may save this as my winter project. This will allow me some 'zen' time and come up with better solutions........maybe!
Also, as most projects happen, it looks like a lay-back seat post will be in order to give more legroom.
Old 09-01-2015, 01:21 AM
Panhead's Avatar
Panhead Panhead is offline
That hub sure is interesting. I am growing tired of replacing batteries!
Old 09-03-2015, 07:21 PM
xseler's Avatar
Who am I kidding??!! My gas tank project won't last till the winter.....
Fabbed the front mount this afternoon. It'll attach to the underside of the top bar.
Tags
MotorBicycling.com
