Old 07-22-2015, 11:11 AM
DRBS's Avatar
DRBS DRBS is offline
thats like the customer that wanted his bike he ends up over here as i was taking the bike out for its maiden voyage and you all know we have to work the bugs out and it takes a little bit longer sometimes well this guy was like why you doing that everything i did he was just right there over my shoulder i told him i would call him when its ready to go and he just shows up should have told him it would be another day till it was done LOL
hang on a second I think ill use my nox now
Old 07-22-2015, 12:28 PM
tgaydos's Avatar
tgaydos tgaydos is offline
not today but forgot to post yesterday, I changed the plug and plug wire end, also cleaned the tires and spokes late last night, I ordered a new HD lightening CDI and a sunlite speedometer.
"The most important thing is to have a good relationship with your bike you have to understand what she wants."
Old 07-22-2015, 12:57 PM
thxcuz's Avatar
thxcuz thxcuz is offline
my ride has been doing well these past few months and I decided to give it a real test. There is a music shop a bit away, Not too far, I've gone there on my schwinn Continental 10 speed before, trouble is there is a big old hill. It wasn't easy getting up it on a bike but I thought my cycle motuer could make it. It got up the hill but not without some fussing and cussing on the bike's part. By the time I got to the top it wasn't running. Turns out if vibrated so much the choke lever moved over and killed the engine. I rode home and decided to stay in my neighborhood for now.
I have a need for slightly increased speed
Old 07-22-2015, 06:54 PM
crassius crassius is offline
used to have my pant leg throw choke on every so often - I bent that lever a bit on my daily driver to prevent that
Sometimes I sets and thinks, sometimes I jes sets.
Old 07-23-2015, 09:11 PM
knightscape's Avatar
knightscape knightscape is offline
Found a staple buried in my rear tire through my tube (completely flat) after I got off work from the commute this morning, so I swapped my rear tube out for a self sealing version after work then rode home. Gave me a good reminder to double check all my tools and spares that I carry, because I found I was missing my pump and tube from my bag. Luckily I keep a pump at work and a buddy drove me to grab a quick tube.
Old 07-23-2015, 09:22 PM
DRBS's Avatar
i have tried those self sealing tubes and found that there not worth the money i buy the puncture resistant one and get better wear out of them there thicker and the friction that these bikes make will pop a normal tube in a little time but these last a long time
Old 07-24-2015, 08:55 AM
BOYGOFAST BOYGOFAST is offline
https://youtu.be/ARfKuP1Si_A
Well I'm yet attempting to finish this, it requires a rear brake or a way to engage the coaster on it.If had it running and apart several times and no joking currently no brake on it. My plan currently is to remove the jack drive and mount an Archer on the frame the same setup as was featured earlier on this website. I'd like to keep the Nexus but I can't figure in a way to get it to stop and go once it go's. Any suggestions ? Got a few bolt on's that work running a GT 5 piston cut to fit in this with a generous 3 mm x 47 mm increase in the combustion chamber don't not much loss of power but haven't got it opened up in 3rd will likely reach 60 mph easily on these tire tub/wheel set. Anyway not sure if this is seasoned enough for some but here it is again just lately..
Old 07-24-2015, 09:47 AM
I resolve the chain tension issue and got this running again has decent torque with the Nexus 3 but in 3rd it pulls and keeps pull I backed off it about 55 and with no brakes on it it took a long while to slowing it down on the shoulder of the county route. Anyway I estimate it will break 60 without effort this tire and wheel set is great for oil and chip but will likely ware out in a few months of steady riding .Yes it runs well with the larger combustion area granted by the GT 5 piston the ports open quicker stay open longer and it likely runs cooler overall but that's my estimate on the piston swap,the bottom of the piston skirt had to be radius cut to fit the connecting rod modification was to remove to center section,the piston trimmed thin all way round the inside the wrist pin is cross drilled and polished on this assembly as well these are the basics. The reciprocating weight attached to the crankshaft is much less but I did not remove the crankshaft to fit a solid steel rod journal so is still a lightweight far as rebuilding one of these. The work I favored was easy but without a working brake on this bike it's not stress proven I work it up to 3rd at low rpm's ,it will move..No fancy work done actually.
Old 07-24-2015, 05:52 PM
xseler's Avatar
xseler xseler is offline
Today wasn't a "what did you do to your motorbicycle" day. It was "what did you do to your shop area" day. Did the full maintenance routine on the compressor --- fresh oil, new regulator, new 50' rubber hose, new couplers on the hose ends and on all tools, and cleaned the air filter.
The new regulator really helped the performance! I didn't realize that I wasn't getting full pressure. I guess that slow changes and my age combined to dull my ninja senses.....
You're never lost until you run outa gas.
Old 07-25-2015, 08:49 AM
tgaydos's Avatar
Went to go start it for my morning ride to work only to find i had super low compression and it wouldn't start. i put in a new headgasket and base gasket because i did some mods on the piston and decked it a little bit. It turns out that one of the connectors rattled a little loose and that connection grounding out was the reason for non start. I also put on my new HD lightning cdi and sunlite speedo, I was super stoked to find both in the mail box last night.
Tags
MotorBicycling.com
