Old 06-17-2015, 11:33 PM
DRBS's Avatar
DRBS DRBS is offline
i use the duplicolor metalcast paints and there regular engine paints all the time there great paints for these engines try the universal chrome they have its the BEST CHROME PAINT I HAVE EVER USED also try the clear effex paint its a prysmatic paint that will turn you paint job into a rainbow paint job and ive been painting for a loooong time i use to paint hot rods for the autorama here in detroit check out www.scarryfnlarrys.com
hang on a second I think ill use my nox now
Old 06-18-2015, 02:58 AM
Panhead's Avatar
Panhead Panhead is offline
My Skyhawk frame is now a (barely) functioning ride. Tires, tubes, & front wheel arrived the past couple of days. I created a rim strip from an old tube, got everything mounted, replaced the rear axle with one that gives me some room, & dug through parts until I found a seat post, chain, and a unmatched set of pedals.
I've almost forgotten what it's like to use a coaster brake! Definitely some refining to be done, but the bicycle is here. Pretty soon it will be time to begin on the motor-bicycle.
Old 06-18-2015, 03:01 AM
Panhead's Avatar
Originally Posted by Southgate Jonny View Post
Had a stripped exhaust stud hole so I tapped out both holes to 5/16"-18:
Got a longer plug wire so I could mount the cdi under the engine:
Installed a small solid brass petcock to keep the fuel line away from the head:
Pretty creative - worth remembering.
Old 06-18-2015, 09:58 AM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
Originally Posted by Springfieldscooter View Post
Today I learned that ALL these brand new Chinese made engines need to be examined carefully, before installation!
My brand new engine kit, had 2 base gaskets installed from factory.
Ive learned that others have experienced cylinders that were installed backwards, and other engines with 3 head gaskets!
I found out the hard way that the factory will use mismatched parts. If they got the wrong cylinder or a piston rod too long they'll just add gaskets to keep the piston from hitting the head. ALL they care about is getting yer money out of your account. EVERYTHING ELSE is YOUR problem. And yeah, ya gotta inspect everything.
Red.
Old 06-18-2015, 11:23 PM
xseler's Avatar
xseler xseler is offline
Only changed the name of my ride --- sorry, Shan.....
You're never lost until you run outa gas.
Old 06-18-2015, 11:26 PM
Davezilla's Avatar
Replaced throttle and clutch cables on customer's bike and readjusted clutch, added a few more coats of grabber green to the specialized frame's front triangle, then I will redo the rear triangle in semi flat black, I've also stripped the original yellow paint off the rear spring so I can powder coat it lime green.
Got the presta valve adapters in the mail today so I could put air in the fixie's tires, and hopefully this weekend I can have an engine installed in that one so I can have something to ride while I'm redoing the mountain bike.
Old 06-19-2015, 08:07 AM
knightscape's Avatar
knightscape knightscape is offline
Xseler, can you tell me about the direction your head is facing? I thought slant heads were supposed to have the plug facing forward for some reason? I don't know it if matters and I realized I don't have any idea why I thought that. Does it not actually make any difference?
Old 06-19-2015, 10:16 AM
Greg58's Avatar
Greg58 Greg58 is offline
You can run the head either way, I found on one of my engines that it runs better with the spark plug to the rear. I don't know if the head mates the cylinder better or what the difference is but I can tell it.
Your results may not be the same,Greg
Old 06-19-2015, 11:00 AM
fatdaddy's Avatar
I've done it both ways. It doesn't seem to make a difference. I did it usually because of the CDI and where I wanted it mounted. To keep the plug wire off the head. But performance wise I could tell no difference at all.
fatdaddy.
Old 06-19-2015, 06:12 PM
Panhead's Avatar
The project is now a ride-able bicycle. Now awaiting motor mount. . .
Tags
MotorBicycling.com
