Old 04-18-2015, 07:12 PM
DRBS's Avatar
DRBS DRBS is offline
I found the John deer paint at Napa auto parts
hang on a second I think ill use my nox now
Old 04-18-2015, 09:43 PM
bluegoatwoods's Avatar
bluegoatwoods bluegoatwoods is offline
DRBS!
I didn't know you were color blind. I'm so sorry.
But don't take me seriously. I'm just being a bit of a smart aleck. More for the fun of it than anything.
It is a nice paint job.
Old 04-18-2015, 09:48 PM
DRBS's Avatar
I thought I painted it john deer green oh my god it is NOT!!!!!! damn I guess I am color blind LOL no I saw the green his is painted when I went and got this green my buddy pointed it out saying I should paint it that color
Old 04-18-2015, 09:53 PM
DRBS's Avatar
well I got the 6 volt to 12 volt buck step up boards today the only problem I can see is they will only have an out put of 500 MAh at 12 volts so they would power leds and charge your phone or a GPS or a tablet but will not power a stereo but ill still set them up with a cigarette lighter plug and a switch for lights that way you could run a nice set of lights on your bike
Old 04-18-2015, 10:16 PM
fasteddy fasteddy is offline
When I was building the tri car I found that there are two wall thicknesses when buying tubing. There is 1/16th and 1/8th. If you buy 1/8th wall the inside diam. is the next size down. For instance 1-1/4" outside diam. is 1" inside diam.
Steve.
Old 04-18-2015, 10:27 PM
DRBS's Avatar
I found some on e-bay its 1.25 id and1.50 od I figure that cutting it into two pieces will leave enough so that there is room for forming it around the hub I'm also going to use a chisel to add a few gouges in the inside and out side to keep it from spinning on the hub also do the same to the inside of the hub adapter better safe than sorry but ill try it slowly to make sure it doesn't slip ill mark the hub and the adapter to check that it isn't moving if it does then back to the drawing boards I just might use a 1" one and use a hole saw and re cut the hole 1.25 well actually 1.20
Old 04-19-2015, 04:59 AM
Panhead's Avatar
Panhead Panhead is offline
Originally Posted by DRBS View Post
hi there panhead you can get a billet mount at gasbike.net there really nice and you can paint them any color you want
Another site to check out - I've already found a low-buck solution on eBay I'm going to give a try & have the Mozo front end tucked away for another project. I've wondered what it might be like to build one from scratch, maybe with a frame that contains the tank.
Old 04-19-2015, 05:02 AM
Panhead's Avatar
Originally Posted by knightscape View Post
I've had a bad itch to go riding lately, here in Maine we're just getting to warm enough temps so today I blew the dust off my bike and fired it up for the first time since fall. Over the winter put on a new saddle with the help of one of sportscarpat's awesome layback posts. I also had to rig up a reinforced muffler support, a little piece of steel bar stock and a torch to bend it good and sharp took care of that. The stock support from Phantom was just not rugged enough and fatigued and snapped (coat hangars got me home that day LOL). Lastly, added some mirrors for safety as my last 5 miles to work is along a very busy road. Looking forward to warm sunny days here.
Before:
After:
That is a neat looking ride!
Old 04-19-2015, 05:14 AM
Panhead's Avatar
Today I did get the computer mounted & functioning, and it does add to the fun. Also, while digging in the garage Saturday I came across an old bicycle headlight I decided to mount. While it does not work yet, I think it looks cool. I think it used to go with a generator, ages ago. It definitely adds a bit of character.
The computer is the same model I use on my Motobecane road bike & if you can find one at a good price they're the way to go - have all others topped hands down.
Old 04-19-2015, 09:55 PM
Davezilla's Avatar
Since I don't open my shop on Sundays and my wife wanted to go out shopping with her friends it was the perfect time for me to go to the shop and mess with the Stingray build I'm in the early stages of doing...
Today's progress was stripping the bike down to just the bare frame and taking the fork apart... completely apart, every nut and bolt off apart...
Got the triple tree parts and dipped them all in the carb dip tank for about 30 minutes to remove all the paint from everything as well as any grease or anything else... After a 30 minute dip in the Berryman B9 Chem dip, the paint released it's self and washed right off with water. Once the parts were completely free of paint, rust, grease, and clean I let everything dry real nice and begun powder coating all the small parts as well as the upper and lower tripletree pieces. these were metallic candy red but I'm going with semi gloss black for most my pieces so today I was doing all my powder coating in semi gloss black.
i also worked the fork legs, kick stand, and bottom bracket getting rid of all the rust and removing decals etc, the kickstand I decided to paint semi gloss black with the Plastikote ceramic engine block paint, it matches the powder coat black almost perfectly and sticks to the chrome a little better, not to mention makes touch ups later on real easy if needed. I'll most likely just powder coat it later on after I get a sand blast cabinet to blast off the chrome, but for now this will work.
The fork legs were covered with rust so I got out one of my 4" angle grinders and used a 4" wire cup brush to get rid of the rust and remaining decal residue. The fork legs will also be painted instead of powder coated once I'm sure of what color schem I'm gonna go with, but I'm really leaning toward semi gloss black and lime green as my main colors with some green tru fire airbrushed on the frame and tank when I get that far with the build...
I didn't mess with the engine for it today at all but I'll do more with it after I get a set of billet mounts for it. I still need to buy a seat for this one and it's going to need a new chain on the pedal side since the chain that's on it has a section where the links are rusted beyond help, the rest of the bike and the frame aren't very bad, but the chain has a 4" section that's so bad the links won't move freely anymore so I'm not even gonna try to save that one.
Other parts I still need to round up are fenders, seat, chain, and brakes. I'm thinking about doing hydraulic disc brakes front and rear since the rims will be painted and rim brakes ruin painted rims... I'm also thinking about getting a set of hydraulic front forks foo a small dirtbike or moped if I can find the right diameter and length fork tubes that can fit in that tripletree, but I may use a full tripletree if I have to.
Tags
MotorBicycling.com
