Old 04-09-2015, 08:32 PM
DRBS's Avatar
DRBS DRBS is offline
I could but then there is always a chance for junk too I had a few motors that were the 2010 models that they said were 2014thats the problem with using e-bay for the kits I found one guy that was giving me free replacement parts for a year but he stopped selling them he was having to give more parts and kits for bad ones he went out of business just goes to show there are a lot of these motors that are bad from the factory I had two that the mag coils were bad from the get go that pissed me off so I ended up buying 20 at 6.99 each from him and a few cdis too
hang on a second I think ill use my nox now
Old 04-09-2015, 11:20 PM
mapbike's Avatar
mapbike mapbike is offline
Yep the old crap shoot rule applies to this day.....
Forrest Gump made a similar statement about the box of chocolates...lol!
Thats one reason I like dealing with Duane @ thatsdax, always feel confident in the product he sells, yeah a lemon can pop up anytime anywhere, but he dont have much of that because he takes the time to make sure to the best of his ability you get a good engine the first time.
To me thats worth a few extra bucks.
Old 04-09-2015, 11:37 PM
DRBS's Avatar
yea that's what everyone tells me and ive talked to him a few times he really seems to know a lot about these ive tried a few other guys and im not really happy but you live and learn .I have tried at least 9 different sellers and found that there are some really sleazy ppl out there and then you find one that just blows your mind. I found a guy selling the ign boxes and there cheaper than anyone else and they are the same exact thing then you find ppl that just take advantage and when you contact them they want to refund you when you know more than they do LOL im working on a box that attaches to the white wire and will change the 6volt to 12 volt so you can power your lights and even charge your phone/ laptop /car stereo ect im going to be selling them for 49.95 figured that ppl would like to take advantage of that free white wire and make something with it LOL
Old 04-09-2015, 11:48 PM
Davezilla's Avatar
Same here.. I know anytime I buy a Dax engine its going to be good, and if by some chance I do get a lemon a replacement is only a phone call away. So far ive only had one issue with a bad mag coil but I keep spares here at home and at the shop so I'm not counting that against him nor did I bother to call him about it, just swapped it out andnit fired right up... I'm sure if I called him on it he would have replaced it no questions asked but since I always keep spares there was no need to. Anyway I wanted a bad one to experiment with rewinding so now I got one in my stash somewhere...
I did take a gamble recently on a super rat bottom end and now I just need the time to set it up. So far it looks great with the good hardware where it needs it, the crank looks good and so does the rod, piston, cdi setup, and clutch. I will put a jug on it this weekend and see how it runs on my silver bike while I'm doing more upgrades to the Dax engine it has in it now... I will give a full report on how well or how not so well this engine works, but from what ive seen so far the build quality is excellent.
this one uses the one piece crank with the ZL rod so I need to look up what length that rod is. It does use the low pin piston so I'm assuming the ZL rod is one of the shorter ones. There is also zero play in the wrist pin bearing and the big end bearing so this should turnnout to be a nice engine when I'm done with it. I've also ordered onenof those billet heads that looks like a rounded off Fred head so I'm going to put that one on the Dax engine and the Fred head on the super rat.
Today both my OCC stingray wheels came in and they're both in excellent condition, the rear wheel may need new bearings but I think I got spares at the shop if it does, I'm also planning to use the manic type hub adapter and the billet mounts from pedalchopper on this one for a really clean looking install and I may use a 3 speed hub as a jack shaft/ transmission but ill look into that more after my frame gets here... I'm also planning on using a c9 seat and a solid layback post and finishing it off with ape hanger bars to get the look I'm after.
Old 04-10-2015, 12:08 AM
DRBS's Avatar
yea I like the hub adapters I plan on using them on every build from now on there a lot better than that s&%ty rag washer crap you just bolt it on and your done no tighten this bolt a little more tap it here now tighten this one ect its terrible and ive seen a few with the spokes ripped out of the rim. im going to buy a bottom from Duane and build my top end I just got a new set od burr bits and cant wait to use my new dremel angle head I just bought so I don't scream and yell cause I cant get to that lip in the transfer boy is that ever annoying hoping to sell two more bikes soon so I can get that bottom thinking about selling a few done cylinders when I get them in I ordered 4 of them last week should be here by wed
Old 04-10-2015, 12:50 AM
Davezilla's Avatar
That's pretty much the same thing I do by buying Dax lowers and building up my own top ends... yeah if you got a set of those carbide burrs you'll love the way they work and can reach into places not reachable before. I got onenof those angle heads for the dremel and didn't like it too much but I got angled die grinders that work great depending on the task at hand. One of my favorite grinders I got is that micro grinder from harbor freight, these are also known as pencil grinders and it lets me knife edge the top of the transfer port as well as reach all the way up the transfer tunnels. If you got at least a 30 gallon compressor I would highly recommend this one as well. And another tool that reaches those tricky spots with ease is the pneumatic file since you can use the included files in that kit or you can use jewelers files. Its not as air hungry as the pencil grinder so you can get away with a 15 to 20 gallon compressor with that one.
If you don't have a big compressor the dremel and the carbide burr set you got can still do very well. If you got or plan on getting a set of those diamond coated burrs they are really good at finishing or doing precise work where you need a lot ofncontrol instead of raw cutting speed, these work best lubed with a good cutting oil like tap magic or boelube, then use high rpm with a very light touch, these do well for finishing the transfer cleanup and other jobs where precision is needed.
You'll do quite well tho with the dremel and the carbides tho, the other tools I mentioned just make the job easier but the dremel, the angle attachment, and a good set of carbides is really all you should need.
I'll post pics of my latest port Job in the morning after I get to the shop... its tricky and time consuming trying to post pics from my kindle...
Old 04-10-2015, 01:21 AM
DRBS's Avatar
ok so for you guys that have or thinking about buying a Jake's head you will need a NGK B8ES plug it has the longer reach but the same heat as the B8HS
Old 04-10-2015, 01:28 AM
DRBS's Avatar
yea I know all about the air files I use to build custom hot rods with my buddy for the autorama here in Detroit ive been messing with internal combustion engines since I was 12 with my first garbage bring home rototiller motor that took me a whopping 2 hours to get it running then went to my grandpa that was a welder for Wyandotte chemicals and we made a go cart and that was where I got hooked on driving and building bikes and carts. my uncle had a triumph trident motor and we were going to put that on a bigger cart and drive that buy grandpa said he wanted nothing to do with that now I look back and think that was a good thing that he didn't make that I just might not be here today LOL IM just saying LOL oh by the way im 51years young
Last edited by DRBS; 04-10-2015 at 01:30 AM. Reason: forgot sometimers catching up with me oh yah i remember why LOL
Old 04-10-2015, 01:48 AM
Davezilla's Avatar
Your story sounds very similar to mine... but you know what tools will work if you got that kind of experience... my first engine was an old riding lawnmower that had a 4 Hp Briggs engine... I was 9 years old and my dad bought me my own toolbox because he got tired of me always taking his out of the truck to work that engine... lol... one time I took his toolbox out of his truck and forgot to put it back, he didn't check to see if it was there either and showed up to work without it. He went to go get it and thought somebody stole it. I thought so too until I went out to our tool shed and it was still in there next to that engine.... oops...
anyway I got that thing running when everyone thought it would never run again and after that I was everyones go mart and minibike mechanic while I was young.
I did the same thing when i got my first car and made it into a hot rod... as well as just about every car I've ever owned.
I spent most my career as an aircraft mechanic and also learned and begun doing structure and sheet metal work while inwas working at Boeing. I stayed there for 15 years before getting laid off last year and then I used my severance pay and 401k money to open up my own auto shop. I didn't see a profit for the first few months then about broke even back in February and started turning some good profit about mid February and early march. The shop is doing very well now but most everything I make goes back into the shop to get more and better tooling and equipment etc.
I'm also working it 6 days a week and sometimes going in on Sundays to keep up with all the work coming in. I had to hire a mechanic last month but I'm looking to hire another one real soon so we can keep up and just work 5 days a week.
I'm only 46 years old now and the only difference between when I was younger and now is the type of toys I got...
Old 04-10-2015, 02:03 AM
DRBS's Avatar
I know what you mean I use to do mobile auto and truck repair and the money was GREAT I was in Jackson TN and making a killing then they changed the law on mechanics and there I went no more work cept for a few ppl that liked my work they had to say it wasn't money for working on there car it was paying a debt they owed me believe it or not the police would stop you working on a car and if it wasn't your or a family members you would get a 500 fine but yea its fairly easy work to get these running like a raped ape LOL ive got tons of parts and quite a few cylinders I bought them from china and there really nice the ports are cleaned up better than most for 20 each there pretty fair priced im going to buy a lot more and start porting them for sale on e-bay LOL im also working on a box to turn the white wires 6 volts to 12 volts to run led lights cell phones laptop ect ill post them when I get them done thinking they will be around 49.95
Tags
MotorBicycling.com
