Old 01-10-2015, 06:00 PM
scotto-'s Avatar
scotto- scotto- is offline
Custom 4-Stroke Bike Builder
Smile Re: what did you do to your motorized bicycle today?
Originally Posted by culvercityclassic View Post
Chop... Drop.... And some new clothes to come. Shortened the wheel-base, lowered the rear and added new drop-outs. Working on brakes and choice of frame color are next.
But brakes will slow you down.........think Speedway!
On a serious note, that's a real fine looking board tracker there Jeff and I hope to see you racing it in the midclass. That would be a real contender, especially with the CVT and all.
Nice work man......leave it raw.
EZ Motorbike Dealer - San Diego, CA.
http://www.ezmotorbike.com/
Nothing is out of my realm,
if it doesn't fit, make it fit! Beer is the answer....what was the question?
A sense of humor costs nothing, why don't people use them more often?
"You can't buy respect.....you have to earn it"
Old 01-11-2015, 02:51 PM
Gbrebes's Avatar
Gbrebes Gbrebes is offline
Hey Everyone,
I was riding my bike the other a month or so ago and it all of a sudden started loosing power and finally shut down. Took out the engine and removed head cover to discover my exhaust rocker had cracked. I replaced it with a spare I had, but that cracked as well after a couple of weeks. Puzzling to me, I do run the engine without a governor and I ride it fairly hard, but I can't figure out what is putting so much stress on the rocker arm. Anyway, I brazed the last one back together and will be testing it out when the rain stops here.
Also working on an alternator system. Got a tip from member Bigoilbob on a small brushless alternator that seems built quite well. I did have trouble with using a solar power control box as a regulator, just couldn't get it to work, so I have now switched to using a small motorcycle voltage regulator. Haven't got to run it for too long, but nothing has caught on fire yet, so that's good.
Pics of cracked rocker arm and alternator brackets, as well as alternator installed.
Gilbert
Old 01-11-2015, 05:07 PM
mapbike's Avatar
mapbike mapbike is offline
Valve spring tension?
Valve binding in guide?
Valve tapping piston at high rpm?
Maybe none of these things apply at all, just rolling this around in my head thinking of potential possibilities
Old 01-11-2015, 05:46 PM
GoreWound's Avatar
GoreWound GoreWound is offline
Gbrebes, by the look of that part I would guess that it shattered which only really happens to hardened metal, you may want to look into heat treating a replacement for part to make it less brittle. It's possible that the vibrations are shattering the part.
That said softening the metal can very quickly become the opposite problem whereby the part bends...
Good luck, and by the way, your bike looks awesome!
Ask me about Chainmail in southern Ontario!
Old 01-11-2015, 08:22 PM
Gbrebes's Avatar
Hey guys, thanks for the ideas on the rocker arm failure.
I forgot to mention its a Honda GC190 with overhead valves. I am not a very knowledgable mechanic, so I wouldn't even know how to check if the valve spring is binding. I had another engine where the valve stem was sticking in the guide, but that just left the valve hanging open and the motor not getting enough compression to start.
So hopefully my brazing it back together will hold. I added a little extra brass to the area to make it thicker and hopefully stronger.
Thanks,
Gilbert
Old 01-11-2015, 08:51 PM
Davezilla's Avatar
Well today I went to the shop while my wife went to a visitation for a friend of hers that recently passed away so she dropped me off at the shop.... I decided this would be a good time to see what's wrong with my clutch. Took it apart and noticed the clutch bell felt a little sloppy, but it was intact so I pulled it and saw that the bevel gear part of the centrifugal clutch was just pressed into place and it became loose enough to spin freely. So for now I took off the centrifugal until I can take it apart and braze the gear to the bell again. It was working really well for me one day then the next day I was going to run down to the store down the street for some change and it just reved without going anywhere... no warning at all, and it worked fine the day before....
Anyway, if I want to keep using the centrifugal clutch on my setup I'll need to take it all the way apart, de grease everything, then braze or tig weld the gear back in place.... for now I just put the regular bevel gear back in and got it rideable until I can the part back together. If I do decide to braze in because it might be safer to braze, I'll use nickel/silver brazing rod because of it's strength.
Old 01-12-2015, 08:31 AM
Davezilla's Avatar
Took the bike for a test ride this morning to my favorite little Mexican resturaunt for some tacos, everything works just fine again... I just have to pull in the clutch as I slow down now and release it when I wanna go instead of just twisting the throttle, but I'll fix the centrifugal tomorrow since I left my nickel/silver brazing rods at home in the garage instead of bringing them with me this morning...
I also set up the GPS to see if it effected my top speed but it was reading 41mph so the gain without it or loss with it installed is pretty much negligable, the bike is feeling and going a tiny bit faster erach ride as I'm just a bit passed halfway thru the second tank on this engine so that could also be why I picked up an extra mph.
Old 01-12-2015, 09:20 AM
mapbike's Avatar
Dang-it Dave, its 36 F here drizzling rain, heavy fog this morning and just plain nasty out.
According to Bing.com/maps I'm 194.8 miles North and just a tad west of you, sure wish the weather here wasn't this way, I was itching to ride a bike today, but i ain't gonna do it in the drizzle and mud.
Old 01-12-2015, 01:51 PM
Semaj's Avatar
Semaj Semaj is offline
Electric Enthusiast
Arrow Re: what did you do to your motorized bicycle today?
You should come visit me in austin Im a heck of a lot closer!
Although Probably not nearly as interesting a visit :P I suspect being a Hermit has done nothing to aid me in being an interesting host.
Kick the addiction. Gas Free* since 2014
Havent directly paid for or put gas into anything*
Old 01-12-2015, 07:57 PM
Davezilla's Avatar
Luckily it was a nice warm 48 degrees and dry this morning at about 7:30am, and my trip to the resturaunt is only about a mile away.... I need to warm up the bike for at least 10 minutes for the one minute run there... I've. Taken off cold from the shop but the bike 4 strokes a Lot if its not warmed up most the way to operating temp.
I've also noticed my motorcycles tend to have more power when it's cold outside, with them feeling the strongest at 50 to 60 degrees outside, then that extra power tends to fade below 50 degrees, or above 70 degrees... not a whole lot but enough to be noticeable.... anyway, that's one reason for riding in the cold, and it helps with break in since it takes a bit more to get the engine too hot.
I used to ride the Intruder and the Sportster all the way down into the low 20's or even high teens to work every day for years, I think I finally broke down and started using a cage a few years back when l messed up my ankle and couldn't ride at all, but for several winters my bike was the only one on the highway or in the parking lot when it was freezing cold or pouring down rain.... I even rode thrum sleet before... but that was a bit painful at 70mph...
Tags
MotorBicycling.com
