Old 02-15-2011, 02:33 PM
Skarrd's Avatar
Skarrd Skarrd is offline
replaced the front inner tube.
this weekend i'm going to strip it down and paint the frame : D
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 02-15-2011, 03:03 PM
RebelHellbilly's Avatar
RebelHellbilly RebelHellbilly is offline
put on a new back tire since i kept noticing the spot in the threads of 1 i put on like 2 weeks ago then i had that mishap saturday with the pack of cookies lol...when the tire slid it i guess u could say flat spotted it as they say in nascar lol. the tire i got today was a good deal...$7...last 1 they had wish they hadda anuther would have got it. and it wasnt walmart i got it at either lol a place called magic mart here where the walmart used to be
Old 02-15-2011, 03:20 PM
happycheapskate's Avatar
I found these Cheng Shin / Bell Streamliner 2.25s on fleabay for $7 each
http://motorbicycling.com/members/ha...-2-25-tire.jpg
I got one from Walmart yesterday for $15 before I found that, and its good. Its a big, soft tire, rides nice, stops great, corners ok. For $7 can't beat it! Great for spares too because they can be rolled up.
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 02-15-2011, 04:05 PM
Skarrd's Avatar
that's the same one i have on the back tire, it feels absolutely great!
They see me rollin'
they hatin'
Old 02-15-2011, 05:25 PM
MarkSumpter's Avatar
MarkSumpter MarkSumpter is offline
Cursed a Rag Joint sprocket to high **** and back for not lining up well after almost 3 hours of grinding out the sprocket hole and mounting the darn thing...
Old 02-15-2011, 08:40 PM
Eazymoney Eazymoney is offline
put a new tube on today after a week..adjusted my brakes..rode around my neighborhood took it back home let it cool down jumped back on it about 45 minutes ago with a flash light cause its dark outside found this long straight road and just pulled the throttle all the way down till i hit top speed i had to be flying about 47mph then i just went cruising around the neighborhood again
Old 02-15-2011, 09:55 PM
Dan's Avatar
Dan Dan is offline
Staff
LOL Mark.
If you cursed a rag joint after 3 hrs of coercing.....You might be a MBer
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 02-15-2011, 10:00 PM
Did you make the hole too big? What hub are you using? You may be able to salvage it.
I mounted mine on a hi stop coaster. The stock cog fit right on, but the replacement 36t had a smaller hole (front freewheel cog). I used a half-round file to grind out the center incrementally, and used the pedal side chain and crankset to turn the cog on the file. I opened it up enough to fit in a short time.
If you have a common freewheel or cassette hub for geared bikes, check out the hybriped sprocket adapter, $50. I'm getting one for my next motorized bicycle if it isn't friction drive.
Old 02-16-2011, 12:02 AM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
I finished, and tested, my vintage-look carbide lamp styled headlight housing. Installed the bulb socket and reflector-lens assembly, wired it up, and turned it on. Illumination!!!! It works! It works effin' GREAT! And it looks cooler than anything I could buy off the shelf (except maybe a real vintage motocycle carbide lamp)! I'm so pumped about it. I love it when a plan comes together.
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
Old 02-16-2011, 05:00 PM
Goat Herder's Avatar
Gutter Rider
I spent hours researching tires for my new build. I am not going to spoil the surprise yet. Will share in about 3 weeks! It will be full sus. Here is a sample picture of what the tire profile will be on it. Note this is not the actual bike. The bike will have a in frame motor
Tags
MotorBicycling.com
