Old 11-04-2010, 12:32 PM
biknut's Avatar
biknut biknut is offline
Originally Posted by WildAlaskan View Post
i compared the gt5 cylinder with a gt4cylinder and found several differences first the cylinder apeared to be smaller on gt4 the bottom port openings for the gt4 were smaller and more fit to the crank case also the exaust and intake manifolds were smaller on the gt4 the gt5 indeed had better breathing capibility stock
notice the awesome stock paint the black cylinder is gt5 and silver is gt4
Nice pics. Thanks, I've never seen in there before.
Old 11-04-2010, 12:51 PM
darkhawk22's Avatar
darkhawk22 darkhawk22 is offline
Went to Ace Hardware and got a 3/8 fitting for my gas tank and a 3/8 tap. Mounted up the glass fuel bowl and added larger fuel line.
Old 11-04-2010, 06:51 PM
Skarrd's Avatar
Skarrd Skarrd is offline
got a speedometer for it, then laughed my a** off when it kept resetting.
time for resistance wire
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 11-04-2010, 07:33 PM
Originally Posted by Skarrd View Post
contemplating getting a coaster brake hub for the bike... just not sure how well the thing will fit a 135mm dropout spacing...
according to shimano the axle on the CB-E110 is 165mm wide. Shimano CB-E110 Single Speed Coaster
Why? Isn't that going backward?
Old 11-04-2010, 07:35 PM
ok ok so heres the story
first off i got a new gt5 motor and complety dissasembled it. that wasnt the problem the problem was after looking at how the crank case tranfer ports lined up with the cylinder transfer ports i realized the case ports were way smaller than the cylinders
well to move on i decided to match the crank case to the gt5 head and it worked till i decided that the flow into case should be smoother and thats where i got into trouble i ground throu the case into the magneto compartment
i went to a welding shop and asked what it would take they said 100 bucks an hour so i was like frack that ill just buy a new case but then my neighbor just got back in town hes a aircraft mechanic who hasnt tigged in a while i gave it to him to see what he could do about it
so theres the story ill include some pics of the case i still have matched to cylinder port and the two different cylinders gt4 and gt5
Don't feel embarrassed; this is R&D...research and development for benefit of all.
Old 11-05-2010, 12:45 AM
Whizzerd Whizzerd is offline
Like a kid at Christmas, mounted a new engine(Mitsubishi TLE 33) on the BMP unit and rode a bit. Brrr, gettin' cold here! Very nice running 2 stroke BTW.
Old 11-05-2010, 01:39 PM
Skarrd's Avatar
got a front flashing headlight and a rear flashing tail light.
also took some scrapped resistance wire from a spark plug wire set i had and put it on the bike. speedometer works now.
i need something to act as the rear brakes, since i don't have one anymore...
also the bike is converted to a single speed since i have no need for the gears...
They see me rollin'
they hatin'
Old 11-05-2010, 08:33 PM
Oh, okay...single speed.
Old 11-05-2010, 11:02 PM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
Moved it from one side of the garage to the other....needed room for 3 large yard plants... 20 degrees tonight.
Looking for HT's parts?
MY PARTS STORE
HT pre instillation tips.
Engine running problems?
HT breakdown Photos
Ron ><)))))*> Calera, Alabama
Old 11-06-2010, 03:36 AM
WildAlaskan's Avatar
WildAlaskan WildAlaskan is offline
broke down a few times today on my huffy
first the rear derailer was acting up and jammin then my shifter broke so now im stuck in high gear
second i have in the past bent 1 out of 3 sprockets and today another one bent so now im in second gear up and that is slippin every rotation
getting up to speed to start is impossible i had to pull clutch handle then run with the bike drop the clutch put weight on seat while running to start the motor then pull clutch in to keep it running while running next to bike as fast as i can to hop on and start off
oh and if that wasnt baD enough at the clucth handle the adjuster screw vibrated out while riding so i had to use my brake lever as a cluthc handle leaving me with out breaks
it was a rough ride home but i made it with the gears messed up i couldnt even pedal home if i had to
ive got some work to do on sunday im takin tomorow easy
~~~ __o
~~~ _ <_
~~~ (_)/(_)
Tags
MotorBicycling.com
