Old 03-19-2014, 06:47 PM
SuperDave's Avatar
SuperDave SuperDave is offline
Finally finished wiring up the forward controls on my bike. New turn signal switch with high beam & horn button, had to be modified (was internally grounding, smoked fuses when plugged in) and attached to thumb choke lever. Now my handlebars are less cluttered, looks more professional than before.
By the holy power of Love, Life & Laughter, I commend you to Go Forth & Be Awesome!
Old 03-22-2014, 06:49 PM
needtransportation needtransportation is offline
Boutght her some oil and took her on a ride to the gas station and then a couple laps around the subdivision, seems like the more I ride her the better she runs. As soon as I get some brakes for her so I can quit using my feet as brakes she is going to get alot of miles put on her. I dont know what mix the previous owner was using but 2.2 gallons of gasahol and 8 oz of walmart brand oil and she runs much nicer than before and was able to make it up the steepest hill in my neighborhood with me peddling like a madman wich she wouldnt do a couple days ago, I cant imagine how much better she will be when I go to a 56t sproket next week.
Old 03-22-2014, 07:53 PM
mapbike's Avatar
mapbike mapbike is offline
Dang it.... 56T....?
That thing should climb a. Shear bluff with that kinda gearing with maybe a 20mph top speed Im guessing, a 48T should be perfect and still give you a 25mph top speed, my bikes will dang near climb straight up when I put a 44T sprocket on them but with a 49cc I bet a 48T will do a great job and still give you a little better cruise speed.
Just my thoughts but hey its your bike so build it the way you want it, that is all that matters.
Best wishes and hope I just keeps running better and better cor ya.
Map
Old 03-22-2014, 08:30 PM
Greg58's Avatar
Greg58 Greg58 is offline
The 56t will rev the engine a lot so keep that in mine.
Your results may not be the same,Greg
Old 03-22-2014, 09:52 PM
Sgt. Howard Sgt. Howard is offline
FINALLY got my fill of the NT carb constantly flooding the wretched float... dropped the early CNC carb on... had to change controls as well... and could immediately feel the difference in performance. This went on my 'Flying Horse' on a 2010 blue Cranbrick (was called the "Beach Breeze" but now we call it "Grampa")... the Grubee manifold will not fit a FH btw. Used an aluminum 'wedding band' JB welded to the carb end to allow the carb to work. Love the way it handles.
Also started a rebuild on the clutch of a 2012 'Panama Jack' with a similar year Grubee motor- THAT will be finished tomorrow. There's also a 2012 24" Cranny that is (oddly enough) cranberry red... guess what we call it... that will require a minor retrofit of a gasket. Once all three are running, I will install what might turn into the ultimate in low-cost, reliable head/tail/brake/turn lights that run off the white wire... with four penlights as back up/voltage regulators! PLUS, no need for suppressive sparkplugs to allow the flasher to work!
Been buried in work these past few, but the weather is turning good and I will have my wrenching time! These suckers are FUN!!!
Have you ever noticed.... those Polititians who want to ban private gun ownership also want to spend YOUR money like there's no tomorrow?
... Maybe they are afraid of us coming after them...?
the Old Sgt.
Old 03-23-2014, 01:17 AM
Danschutz's Avatar
Danschutz Danschutz is offline
Got my Dyno back up and running this time with a 36T. Scrambles up the inclines no problems and now Im really smoking my pals 4.5 Arrow set up.
Also purchased my first full carbon bike, holy mackerel I thought my Felt was a lightweight this new rig weighs less than half of the Felt road bike. Looking forward to some cardio this year.
Dan.
Old 03-23-2014, 03:27 PM
sboricic123 sboricic123 is offline
I took mine out for a quick rip this morning. It started right up after hibernating over the winter. I put a new spark plug in it and adjusted the chain. I just have to look into the back v-brakes. They seem too loose or not working properly.
Old 03-23-2014, 04:12 PM
Matheneyr3's Avatar
Matheneyr3 Matheneyr3 is offline
Today I stripped the case out- head bolts and heavy hands are a bad combination.
-Been working to eliminate frustration in my daily routine- So....No worries here.
I took 2 drill bits- from just below the gasket surface, from the side of the motor, I drill into the stripped socket....Then with the larger bit, I enlarge the hole I've made. Zip/Zip through that opening with my wire feed welder (actually took a min to get it right) I fill/weld from the bottom of the stud, kind've pinning it in place from the side of the case. Imagine a dowel pin if it were wood.....Torqued it all down and she held!
Short trip ran fine- Time will tell how long it'll stay solid.
No worries- Cheap solutions for Cheap Motors- Or Innovative ideas....it was fun anyways!
-Richard
Old 03-23-2014, 11:55 PM
xseler's Avatar
xseler xseler is offline
I did some 'tweeking' on my Reese Sportwing bike carrier. The trip I made to New Mexico back in the Fall revealed a few issues that needed to be sorted before my next trip. Moved some padding, bent a couple of the support bars, and moved a couple of strap attachment points. Should work much better on my next trip ---- thinking Ohio, Pennsylvania, & Kentucky in May.
You're never lost until you run outa gas.
Old 03-24-2014, 07:21 AM
I cut the muffler off like an idiot, instead of more power it feels like less. I drilled holes in the air filter cover but havent ridden it since to assess the change.
Tags
MotorBicycling.com
