Old 01-30-2014, 12:31 AM
Intrepid Wheelwoman's Avatar
Intrepid Wheelwoman Intrepid Wheelwoman is offline
Cool bike Placidscene. That's a much nicer looking fork and i think you'll find it will give you better steering as a bonus.
I'm building a new cargo tray for my Hercules tricycle at the moment as I'm tired of using half baked lash-ups when ever I want to carry anything bulky or heavy.
Money can't buy happiness, but it can buy chocolate which is almost the same thing
Home of the Kotanga Tramway.
Old 01-30-2014, 12:59 AM
MEASURE TWICE MEASURE TWICE is offline
Maniac57 I looked at it and think in the I can make a U-shape bracket that will connect left to right pillow bearing mounts as one. I will as meaning to do, cut to length threads and have all bolt heads on the inside. The largest sprocket is in place in the photo so I see room. The belt on the left when tensioned is also out of the way.
I should have the engine off to weld with it bolted in place, I can maybe have less warping that way.
I'd be needing to take the engine off to weld other areas for mounting bosses for my skeleton frame. That is what a fish art cover will go over to make it a parade vehicle. Then it will have the big 28 tooth sprocket and the smallest 8 tooth sprocket for around 38:1 to have crawl speed. Then I can have the clutch locked up so not to heat real bad in the desert and be going 3.5mph.
MT
Old 01-30-2014, 11:19 PM
placidscene's Avatar
placidscene placidscene is offline
Today I am still working on lowering my center of gravity on the bike some more.
I was able to lower my Ammo Can panniers 3 inches. They have a battery in them for the lighting, so that should help some.
I also re soldiered the connections on the magnetic sensor for my speedometer that got cut when my first headlight that had a cheap plastic mount vibrated loose at about 25 miles per hour and went through the spokes and between the front fork. Don't know how I didn't get thrown off the bike when that happened!
So now that I think I finally have the bike tuned I can check actual speeds. Excited about that.
In case anyone is wondering, I got the lay back seat post from Sportsman Flyer Bikes. It is great.
What is next? New fuel tank. Should get it tomorrow or Monday.
Old 01-31-2014, 12:02 AM
Cool, roadies make good motorised bicycles. I like what you've done .
Old 01-31-2014, 06:36 AM
phatcruiser phatcruiser is offline
Riding to work yesterday the motor died as I was pulling into work. Bummer. The bracket the carb bolts on to had come loose causing the engine to die....5 minutes later I had the bracket snug and she fired up!
I am going to buy a rear wheel with a velo coaster brake. The coaster brake on there now is A cheap Chinese pos and is almost worthless. Eventually I will swap out the seat and handle bars. But for now they work fine.
Old 01-31-2014, 11:28 PM
I got my new fuel tank today...
It is a little larger than I thought it looked in the picture on ebay! lol
I think I will pull my tank off tomorrow and do a test fit before I spend too much time cleaning it up.
What do ya'll think?
Old 01-31-2014, 11:39 PM
maniac57's Avatar
maniac57 maniac57 is offline
Once it's in the correct position, it will look a lot better. Go for it!
At the least, you will have transcontinental range!
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 02-01-2014, 01:07 AM
That Yamaha tank is going to look way better than the wart.
Old 02-01-2014, 12:48 PM
Cruise's Avatar
Cruise Cruise is offline
Should drop your centre of gravity too. I reckon it'll look good.
Old 02-01-2014, 10:07 PM
Well I didn't have time to test fit the tank today, but I did have time for a short ride.
First time with the speedo working again. It said I got up to 37mph. (down hill)
Bike didn't seem to like me today though. It is moody.
I know it ran better, smoother, higher revs the last time I rode it. I will figure out why later.
It tried to kill me today though... Just after I slowed back down from 37 mph, I pulled over to the side of the road to admire a bi-plane flying by at low altitude and killed the engine so I could hear it. A Leander Police officer slowed down to check me out as he went by, then kept on going, which is great.
When I started her back up and went around the corner, I got this wierd feeling that something wasn't right. I pulled back over and looked down at my front fork. One of the wheel nuts was gone, and the other was loose! I mush have had an absent minded moment when I put the wheel back on Thursday night!
Could have been very bad at 37mph if the front wheel had gone off!
Oh well, all's well that ends wheel!
Tags
MotorBicycling.com
