Old 11-08-2013, 02:31 PM
GearNut's Avatar
GearNut GearNut is offline
Originally Posted by BonusParts View Post
Oddly enough i've noticed that at low rpm it runs great on low throttle input, but at wot it just bogs. not four stroke, bog. Not sure what to make of it. I shortened the header, but it was rainy all day so no test yet.
By bog, if it just looses power and seems to be running flat while you are riding at top speed, it is tuned too lean. It needs a larger main jet.
(Note, a highly restrictive or clogged exhaust will cause this symptom too even though the carb is tuned correctly.)
Now that said, if you whack it WOT from idle speed and then it bogs that too is a lean condition but good luck tuning it out. The carb has no accelerator pump and it cannot accommodate large throttle input changes without temporarily leaning out.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 11-08-2013, 03:37 PM
BonusParts BonusParts is offline
You absolutely confirmed my sneaking suspicion.... I had a feeling I needed to switch back to a .68 jet, seeing as both my crank and head compression have been raised some, that and I noticed it more after I installed the jaguar CDI. I perhaps didn't realized that I had equipped the engine to finally handle the potential of the small NT speed carb....
Well, back to jet seeking!
Old 11-08-2013, 09:44 PM
Cruise's Avatar
Cruise Cruise is offline
I'll throw my bit in amongst you smart lot:
Is there something in being able to adjust the timing at all by gapping the plug?
I'm sure I read somewhere you can advance it by closing the gap, and vise versa.
If so it's another factor to play with.
Old 11-08-2013, 10:01 PM
Intrepid Wheelwoman's Avatar
Intrepid Wheelwoman Intrepid Wheelwoman is offline
I think that might be an old husbands' tale.
Money can't buy happiness, but it can buy chocolate which is almost the same thing
Home of the Kotanga Tramway.
Old 11-09-2013, 12:50 AM
CTripps's Avatar
CTripps CTripps is offline
I can't really see how changing the gap by a few thousandths of an inch is going to have any significant effect on the millisecond(s) it takes for a spark to jump the gap. At a level beyond common measure there may be a difference, but to find it I'd suggest you get good walking shoes and turn right at the decimal point.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 11-09-2013, 03:15 AM
GearNut's Avatar
Cruise, electricity travels at 186,282.397 miles per second. Changing the gap on the spark plug a few thousands of a inch will not affect the timing.
Perhaps you were thinking of changing the gap on the points of a traditional points/breaker style ignition? Changing the gap on that will definitely affect the ignition timing.
The_Aleman:
ROTFLMAO!!!!!!
Old 11-09-2013, 04:23 AM
Cruise's Avatar
Thanks all for your diplomacy and light humour! I've played lots with cars but am new to these cool little motors. Now I reckon I'll leave that gap out of question.
Old 11-09-2013, 10:53 AM
xseler's Avatar
xseler xseler is offline
How's this for an idea??
http://www.youtube.com/watch?v=0Z8dFlVNrY8
You're never lost until you run outa gas.
Old 11-09-2013, 11:44 AM
crassius's Avatar
crassius crassius is offline
[QUOTE=xseler;524721]How's this for an idea??
I note that the vid is considerably speeded up.
Old 11-09-2013, 11:48 AM
crassius's Avatar
I note that it may be the case that a larger gap could cause the spark to wait fractionally for the voltage to climb higher to jump the gap - in fact, a too large gap may cause the spark to wait forever.
Also, this may affect the quality of the spark in terms of its ability to start a good burn.
Tags
MotorBicycling.com
